I installed the Cliffy on my upper PF by Bigfoot, but now when the ball comes out it actually goes to the left before it makes its way to the right. I think I put everything back together correctly, but I'm not sure.
1) There are two holes in the PF to hold the left side of the wire form ramp. I think there should just be one, and I think the flasher attaches to that as well. There is a nylon washer that goes on there as well but I'm not sure between what.
2) I put the protector OVER the end of the spine chiller ramp flap and am wondering if maybe it should go under it, but if I do that it would pitch the protector even more to the left.
3) When installing the wirefirm ramp, I am assuming only one of the posts on the vertical part goes into the associated hole in the housing down by the lower PF.
I have taken a couple of pics and any help would be most appreciated. Thank you..
