Looking for ideas on this one,
maybe someone has had this fault before ?
in test mode Bigfoot will run CCW normal.
when CW engaged he will still run CCW but very, very slowly.
the opto and position tests are ok.
I have removed and checked the bi directional motor PCB for dry joints etc
all appears ok.
looking for tips on how to isolate motor PCB or power driver PCB at fault ?
Voltages at motor are 11v on red 2v on white CCW
11v on white and 11v on red CW
The only clue I have is that Bigfoot recently started running very sluggish in CW direction.
then the error started to occur.
I have stripped down mechanics, motor and gearbox check ok.
Appreciate any ideas
Cheers,
Ando
