Does the coil remained charged or does the flipper just stick? If the flipper is sticking you might try a new coil sleeve. If sleeve is damaged you may need a new coil and/or board repair. If you have the know-how, a flipper rebuild might be a good idea.
George M.
First check clearance to playfield.Then make sure its not hanging up on the ramp directly above.Had that happen to me.If neither replace sleeve next.
Quoted from Pinmeister:Does the coil remained charged or does the flipper just stick? If the flipper is sticking you might try a new coil sleeve. If sleeve is damaged you may need a new coil and/or board repair. If you have the know-how, a flipper rebuild might be a good idea.
George M.
It works for a few shots and then sticks and then works and so on....
Maybe a rebuild then.
My lower flippers don't have that spring that this does?
If you are cleaning up the assembly or doing a rebuild, make sure to not only replace the plastic sleeve inside the coil, but also the white nylon bushing that the flipper rod sleeves into. If either are dirty or damaged, they will cause friction on the assembly.
Quoted from Fintan_Stack:I would try removing the other spring.
The other spring as well as the arm it's connected to. It may be binding against the orbit rail of the lower playfield.
The plastic piece which attaches the coil plunger to the flipper paul shows signs of binding in the picture. My machine was doing this and it had the spring over the coil shaft, I removed that spring and installed the new type which you have already and problem cleared up, so I would suggest looking there, try manually pushing on coil plunger (plunger only with screwdriver) and see if it sticks due to the plastic piece.
And to beat the dead horse here. It is well worth it to do a total rebuild for that flipper. It's fairly easy and it has to go up a steep ramp, nice to have a solid working flipper.
I had this expact problem, the pawl was getting stuck on the EOS switch. Bent the end of the leaf on the switch back and that fixed it. Time to revamp the flippers for me, too. Lots of rejected shots to Insanity Falls.
There are a number of issues you've got here.
1. Coil stop is bent (no longer at 90*), this should be replaced.
2. Coil stop cap screws are mismatched, one is a security bit, one is Allen head. You may have to remove the Allen first, then use Visegrips for the other (unless you have a security bit set).
3. A lazy operator added another spring rather than fix the binding problem on the coil.
I'd get a complete rebuild kit (don't forget to get a new flipper bushing too). Plunger is probably torn up from the fat spring and the sleeve gets worn from the plunger. Kit will have new cap screws and coil stop, too.
Like everybody else said no double springs ever. Rebuild it. The newer return spring linkages with hit against the right orbits guide rail. My buddies solution is to glue an old flipper rubber against that guide rail so that the linkage doesn't make a tinging sound.
This page was printed from https://pinside.com/pinball/forum/topic/wh20-3rd-flipper-advicehelp-please and we tried optimising it for printing. Some page elements may have been deliberately hidden.
