(Topic ID: 1279)
well... i fell victim to DE design
By raijin
13 years ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 13 years ago by jrrdw
    #1 13 years ago
    burnt connector CN8 (GI lighting)...
    DE Tommy... when i bought it ...it had burnt marks on CN8...only thing that didn't work one string of GI backbox lights. i didn't worry... some backbox lights out...who cares???
    it wasn't on route...i would just use the machine lightly (thinking ..less use...less wear on GI connectors ...turn my game off after done)
    well... after having/playing it for 2 months i start noticing that the connector had gotten darker and darker with each play/start up. and now some GI lights are now out on the playfield. i removed connector CN8 and it fell apart in my hands.
    so the question is??
    how hard is it to replace male pins on the board? (newbie here...be easy)
    or if anybody lives in south jersey area and wants to show me how to replace pins...i'll buy ya a case of beer.
    anybody have thoughts about rottendog boards?? seems like a mixed popular review.
    #2 13 years ago
    They are not difficult to replace. Need a desoldering iron, soldering iron and wire crimpers. You can buy the connector as a kit in which the pins are together on a strip of plastic already. All you have to do is push the pin bank into the holes and solder. Then recrimp on a trifurcon connector which should come with the kit.
    Even if you purchased these tools you will still save money over the rottendog. If you have a friend/parent with these tools this will cost you a few bucks.
    But the real question is, what is causing the connector to heat up?
    #3 13 years ago
    well ...from i've read. DE GI CN8 connector is just a bad design. now what i dont know is ...are the IDC connectors the problem or too much elect. flow thru the pins occurred by too many lights on one loop (bad design)???
    read... bad about both.
    i think i will be using LED GI lighting in every pin in the future (DE or not) ..less power.
    my post isnt to discourage any soon-to-be DE buyers. DE has great games TFTC, JP, Tommy, GnR...many more.
    just heads up on CN8 connector and pins!!!!
    so how do you remove/desolder a 8 bank of pins at once???
    do they come out one by one?
    #4 13 years ago
    On older games you desolder all 8 (or whatever) pins and then remove the whole bank. Sometimes individual pins will fall out. Not sure about the newer boards as I haven't had to redo them. The replacement bank usually comes in a strip of 10 or 20 and you cut off however many pins you need. Just be sure not to force the pins out as you can damage the trace. (Done this ) It is repairable but not pretty. If they don't come out real easy, there is still solder in the hole. I am going to have to redo several banks on one of my Sea Witches.
    #5 13 years ago
    k. just didn't know if there was enough heat from soldering gun to remove 8pins at once. i guess i'll figure it out.
    well... i have a 9 pin connector. but the 5th pin isn't used. has a polarizing key in the 5th. so when i order the male 9 pin connector ...do i just clip/cut the 5 pin (both boardside and outward) then install/solder to board. ..and then install...the 4-key-4 male?
    will be replacing female IDC connector aswell.
    i'm just iffy on the board/male.
    #6 13 years ago
    needlenose on one side of pin, heat up solder side of pin with iron, pull snugly on needlenose till the pin comes out, rinse/repeat on all of them.
    Then clean the holes with GET OFF or something like it. and resolder in the new pins in, replace with LED's and never worry about it again.
    #7 13 years ago
    thx maldoror.
    but when get the new 9 male pin bank ....do i clip/cut the un-used pin (#5) both bottom and top of pin? if so with what tool...to make a clean cut.
    #8 13 years ago
    If the extra pin doesn't get in the way just leave it on. No sence in taking something apart if it don't need to be...
    #9 13 years ago
    I've decided to redo the ToM connector - I think if you use a solder sucker you can unsolder one at a time and just suck out the solder - right? I guess I'll find out, gonna order that crap today - or check Radioshack but im doubting they will have it
    #10 13 years ago
    Yeah, you can do these sorts of thing easily with a solder "sucker" pump. Heat up solder and suck all solder out, one pin at a time. I have learned it will help to add some solder before removing the solder. This sounds contradicting but it seems to refresh the solder patch and make the whole lot come out much easier.
    When the solder is gone done, the connector pin will easily come out. I would still make sure to heat the pin, then pull it out with some pliers. Be carefull to not apply too much pressure/pull. Circuit board traces are easily damaged! The pin shoudl come out easy, if not it is not hot enough! Take your time!
    The "key" pin is normally cut of on the top side of the connector. In other words, you do solder it in to the board (probably for extra strength) then cut it at the top side of the connector plastic to make it key. It's always good to key your connector as well so the next buyer of your game knows which connector it is by key (not having to look up wire colors).
    Make sure you get a decent desolder pump, spend at least 20 euros. You don't want the ones that are all plastic. This one is nice (but any antistatic will do!):
    #11 13 years ago
    Well i can't confirm its an easy job. It takes practice and its important not to heat up the header to mutch. Get yourself a desent solderstation.
    About the design flaw.
    I spoke to an amusement mechanic. He told me in the old day thay uses les brighter lamps then that do now. So the simpliest thing you could do is get 47 bulbs and replace your GI lamps with them.
    And now about the DE disign you are a victim of
    Data East made almost a 1 on 1 copy of the disign Williams made. So to be honest. You are victim of Williams design Even Williams WPC pins have problems with the GI. If you have a problem with burned connectors you should buy a pin from "The Ultimate Design". And thats Gottlieb System 3. The titles Gottlieb made are not that impressive. But from all the brand i maintain (at our local pinball assosiate) the Gottliebs System 3 pins never have problems. Its just : Beep beep and you are ready to go. Bally Williams games are a pain in the ass compaired to the simpel System 3 design.
    #12 13 years ago
    Robin Wrote: I have learned it will help to add some solder before removing the solder
    Very simple reason for this happening. When solder is applied flux is used to create a atmosphere ideal for melting the type of metal being worked with (solder). After the solder is applied the flux is used up there for difficult to remelt due to lack of proper atmosphere conditions.
    While adding new solder your adding the proper conditions/atmosphere to melt the metal.
    Today's lesson brought to you by the stuff called "solder"!
    This page was printed from https://pinside.com/pinball/forum/topic/well-i-fell-victim-to-de-design and we tried optimising it for printing. Some page elements may have been deliberately hidden.
