LTG bump
Quoted from Kneissl:Any progress with the controlled lamps?
I did the work to map them out, and have prepared some of the wiring. I stopped as I don't have a router, and after looking into the skills needed (and measuring that against my complete lack of woodworking ability), things ground to a halt. Working on a couple of restorations at the moment, possibly come back to this after those are complete.
Quoted from swinks:I wish this game was made available or planetary build this instead of AFMr
+1
+1
Hope to see KPr someday...
Excellent work, I missed this thread initially. Thanks for uploading the video of your whitewood, looks like a great game with lots of flow and some great sounds,voice and dots. Fingers cross this gets built sometime soon and made available to order. Good luck with your build.
Thanks 73 it is a very fun game, really looking forward to playing it again with lamps as there are some really good effects in this game
Quoted from luvthatapex2:Are you considering doing a playfield overlay? I;ve seen NOS playfields over the years. It shouldn't be too hard to get the art for an overlay. It would be awesome to play this with the artwork installed.
The issue is obtaining a quality scan. Can't see one of the 8 owners stripping down their playfield for that!
The Visual Pinball guys that emulated the table sometime ago had a nice clear scan. If was lower resolution since the table doesn't need it at 300dpi, but maybe they have something pretty good for you to use. I could see if something exists for you if you like.
Quoted from vegemite_nick:The issue is obtaining a quality scan. Can't see one of the 8 owners stripping down their playfield for that!
Quoted from luvthatapex2:The Visual Pinball guys that emulated the table sometime ago had a nice clear scan. If was lower resolution since the table doesn't need it at 300dpi, but maybe they have something pretty good for you to use. I could see if something exists for you if you like.
I ripped the artwork from the VP files. The playfield artwork isn't high enough dpi for using. However, it is full, so it would be good to print one out just to help make sure hole line up, and it could be vectorized by someone.
Where did you get the ramps? Or did you make them? If you made them, you have some seriously good ramp making
skills !!!
Did you pull the higher res artwork from the VPX table? I think that's the highest one available. kingpin 080715a.vpx
Quoted from mjenison:I ripped the artwork from the VP files. The playfield artwork isn't high enough dpi for using. However, it is full, so it would be good to print one out just to help make sure hole line up, and it could be vectorized by someone.
Mark Ritchie had one NOS playfield. No idea where it is now.
Quoted from megadeth2600:Where did you get the ramps? Or did you make them? If you made them, you have some seriously good ramp making
skills!!!
One of the hardest things to sort were the ramps. The left ramp begins with a unique entry, and when I went through my collection of old bits and pieces, found a Data East Teenage Mutant Ninga Turtles ramp, part of which seemed to fit the purpose perfectly, with little modification.
However, the right ramp was another story. I scoured the web looking for similar ramps, and found a lot of candidates, but as I analyzed each one, found issues with radius points etc. Playing MM while still trying to solve this one, I realised that its right ramp was exactly correct for about half its length, and that happened to combine from that point almost perfectly with the other bit of the TMNT ramp. I obtained an old MM ramp, and with some special glue from my mate who has a plastics factory, the Medieval Teenage Mutant Ramp (c) was born!
Quoted from luvthatapex2:Did you pull the higher res artwork from the VPX table? I think that's the highest one available. kingpin 080715a.vpx
I actually used the lamp map from the punmame game for some of placement and etc. I do have a pretty decent option for artwork which I think will work.
Quoted from LTG:Mark Ritchie had one NOS playfield. No idea where it is now.
I remember someone selling one many years ago, would love to have had the forsight to have bought that way back then.
Nick, great job with the project! I hope when my project goes from talk/dreaming to reality I keep with the same dedication.
Once I get my new computer up and running, I'll need a good side project. Vectoring the Kingpin playfield would be fun. I don't have VP, anybody care to send me a high res JPG or something?
Congrat for your work. Were you aware of this another project? Seems serious.
http://thisweekinpinball.com/twip-happy-new-year-two-huge-new-themes-revealed-plus-kingpin/
Quoted from noitbe1:Congrat for your work. Were you aware of this another project? Seems serious.
Yes, very much aware, and that is most definitely the moveable ramp area on KP.
I have been meaning to post a video of gameplay on mine, but wanted to update it to show the pop bumpers working - the attached vid was before I realised that I have reinstalled the top gates the wrong way, so the ball rarely made the pops. I will do a new one at some point.
Wow impressive.
Are you using lcd + P3 ROC like the other one too?
I'm also working on a P-ROC project but so much work you have done for this... crazy
Thanks for the video. Seems great. Is is a Kingpin raw soft or a 2.0?
See post 11. Nick is not using P3-ROC he's using the original hardware/MPU in an airborne cab.
Quoted from noitbe1:Wow impressive.
Quoted from luvthatapex2:See post 11. Nick is not using P3-ROC he's using the original hardware/MPU in an airborne cab.
That's right, it's the plain ROM from IPDB, otherwise the hardware other than the playfield is 100% Airborne.
Quoted from wallybgood:Hey Nick
Your KP is coming along great! Impressive work. Wish that you were nearby.
Wally
Thanks Wally!
Quoted from vegemite_nick:Translite No. 143
Looking the part now!
I recognize that translite. Glad it made it to Australia!
Paul
Nice work. Would be great if you could bring it to Pinfest in Newcastle in Sept.
Quoted from pkiefert:I recognize that translite. Glad it made it to Australia!
Paul
Thanks Paul
Quoted from DMC:Nice work. Would be great if you could bring it to Pinfest in Newcastle in Sept.
A bit too far for me. Real ones will be here soon enough.
Thank you for your inspiration !
Encouraged by this thread I started my own KingPin project and will give a sneak preview soon.
As vegemite_nick´project, my project is also in no connection to other projects. Just a rebuild for my own ....
Quoted from TomDK:Thank you for your inspiration !
Can't wait to see some more Tom!
You’re the man! Can’t wait to see it as well.
You want it ... you got it ...
First there was an idea, inspired by Nick.
All we had was ap picture of a KP playfield. For a first reference this was printed out.
Starting from the scratch would be not possible at all, trust my, I have experience.
So I bought a Breakshot as a good start. Bad thing : It has other pcb´s but I have all needet boards in stock.
Bad surprise afterwards, after renovating the cabinett I figured out: It will not fit due BS has no ramps, etc tha cabinett is "too flat".
next surprise:
The BS has a general illumination directly powered by the transformer and less coils as other capcoms. therefor several pwers were missing. Too bad also 2 x 50 Volt were missing so I added a second transformer for 2 x 50 Volt. Problem solved.
So for the beginning I had a cabinett, the modified ROMs to fit 4 x 512Kbyte , power on and ..... KP alive.
As DMD I use a Pin2DMD due it works with just 12 Volts instead the high power of normal DMD.
Now it was time for my friend C. from Austria. He is a talented and hard working hobby-artist with AI. He spend over 300 hours to bring the pictures of the playfield to a file that is usable for: Milling all needet levels, drilling and printing.
Meanwhile I got familiar with the schematics and all available sources about KP.
... to be continued ...
Quoted from TomDK:You want it ... you got it ...
next surprise:
Fantastic...
Next big step was the playfield ....
So we had a picture of the playfield, my friend from Austria made a AI version. Good to have. So I bought from a "source" original wood as used in pinball machines. Looked all over the world for inserts and got them nearly all. 2 Inserts were made out of opak plexiglas: the powermeter and the big guys head.
Meanwhile we made several proto prints from the playfield on PET-G to have an overview. This short story, told in some sentences was work for some month.
The result is a CNC milled proto white plastic (easier to drill) , several printouts and a CNC milled playfield wood.
Inserts were glued in and a print was done. printed 1 layer white for all areas and a colored layer on top.
As this is the first try we had a little difference in the 2 print layers, we call it "Blitzer". However .. it looks great ! So professional clearcoat was brought on.
Meanwhile I worked on the metal rails and some pcb´s with help of some great german pinheads. First try for the powermeter was a pcb with LED´s , but ... you can guess ... Capcom without a OCD-board do not like any LEDs . So a second version was designed with regular bulbs. A pcb for the 7 lamps on the way to the HotelLex was designed and also some simple 2-lamp-pcbs due KP needs several of them. At least more than I had in stock.
Remember, everything was made out of pictures !
First sketches from the ramp.
wireforms measured on the playfield printout and from pictures
First try LEDs .. does not work ...
Second try with bulbs .. works fantastics and fits
Enough for the moment ...
This page was printed from https://pinside.com/pinball/forum/topic/welcome-to-the-big-city-kid/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
