Working on a project Blackout, I went to take out the MPU to test it and noticed it wasn't a system 6 board; it had an unpopulated 12 pin connector on the top right edge. The two four pin connectors were moved to the left side. Examining it more I noted it has the system 7 style 7 segment display, and it has dual 2114 ram chips like a system 7. But it doesn't look like any system 7 board I've seen. Those have the roms sideways and the 12 pin connector is on the side. The 12 pin doesn't look to ever have been populated. The only marking I see is "5764-09465-01", but that doesn't return a single thing on google
I'm trying to diagnose why it won't boot, but since williams boards aren't screened, and the layout doesn't match any boards I know, I can't figure out which chip is which. Trying to cross reference just off part numbers to a system 7, it doesn't seem like all the connections are the same, though I could just be missing a trace somewhere.
Does anyone know what this is from or where I could find a schematic?
