I'm experiencing odd behaviour in my TOM with switches registering and not registering sometimes.
Recently a couple of fuses have blown, first for the left magnet save, then later for the trough / ball launch.
Now I'm seeing occasional issues with some switches. A couple of times the left flipper has triggered a trunk hit while choosing a mode before ball launch. A couple times actual trunk hits in game have not registered. And it seems fairly often that the right outlane eddy sensor is missing the ball entering the right outlane and fairly often that the right magnet save is triggering on the right inlane switch, and sometimes on no switch at all.
Voltage at TP3 is 12.0V dead on.
Voltage at TP2 is ranging from 5.03 to 5.08 V.
I'm not seeing anything to indicate power issues, ie no Williams reset, LED 1-7 on the driver board are all solidly lit.
The switches I've noticed acting up are not related by row or column on the switch matrix.
I'm thinking I may have a failing chip at U16, U17, U18, U19, or U20, and I should replace these. Does anyone have any thoughts that this may be the best next step (or worst next step?)
Just in case it's worth mentioning, I have pinbits auto adjusting eddy sensors on trunk and inlanes, and also Ingo's Leon board on the trunk, though I doubt any of these are power drains.
