Ok, I'm starting to think that pinball ownership is like 40% play, 60% work.
A weird thing happened to me tonight on STTNG. Last ball, had two balls left in play during the Borg multi ball. Both balls came out of the popper and when I hit the left flipper nothing happened. When I hit it again (perhaps with a little extra force ) the game went dark and the display went wonky. You could kind of make out what was happening, but there was garbage on the screen, too. After a second or two, the display went dark, everything lit back up again, and the display acted like nothing happened. It was not quite a cold reset...it picked right back up where it left off, even did the match and post-game routine.
In the last week I've had a couple times where the left flipper also doesn't behave properly, but it works the second time I push it.
I also had a weird thing happen the other night when locating a burned out flasher. I had the game propped up on the kickstand with the coin door closed so I had high power. I reached in the side to cycle through the test menu, and when I did the game did a hard reset. I don't know what I hit, but it easily could have been the right flipper.
I recall reading the description for a thermistor at Marco, and I'm wondering if that might be the cause? I hate when this stuff happens at the end of the week!
