(Topic ID: 304530)
Weird issue with Fish Tales - appreciate any help
By ramsfan
2 years ago
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by mystman12
#1 2 years ago
Hi All - first, I was having the "Check Fuses F114 and F115" error. After some testing and advice, I took the power board to Chris Hibler, who found the issue, repaired the board, and also replaced some other capacitors, and fully tested it. I just put it back in and am having one of two different issues.
The first is I get a "slam tilt stuck closed". If that happens I cannot start a game. I did inspect the slam tilt switch and it is not closed physically.
Sometimes, I can start a game, but then the ball does not eject into the shooter lane, and then every time I hit the trigger button on the launch reel, it just adds 100,000 points. Again, no ball ever goes into play.
Any clue on where I should start with troubleshooting? I did verifying all the connections being correct with Chris via photos.
Thank you all!
#2 2 years ago
Two slam tilts. One on coin door one on floor of the cabinet near the cash box area. I'd start with them.
#3 2 years ago
Hi there, so I checked both slam tilts, nothing obivous so I Wiggled some stuff, and got past the slam tilt switch closed, but now I can start a game and get this weird issue:
Thank you Lloyd and anyone else who can help!
#4 2 years ago
Can you post a picture of the CPU board from the batteries all the way down to the connectors so we can check for corrosion or something else?
Also a picture of the switch edge test to see which switches the machine sees closed. You definitely have a switch matrix issue.
#5 2 years ago
Thank you in advance! Here is a photo of the CPU board. Also, here is a link to the switch edge matrix and I did a video so you can also see the blinking red light on the CPU board in case that is relevant.
#6 2 years ago
Does the trigger operate properly in test? If yes, pound on the playfield with a fist while in switch test to see if any switches activate. Also, run the reel test to make sure those optos are working properly. Video shows both switches closed and I can't recall if that's correct in attract mode. If those optos are having issues, game ain't going to play right.
#7 2 years ago
You know, keeping in mind I am a total rookie, I just did something that might point to the issue.
I grabbed an extra pinball, and with the machine on, I moved it around the playfield. The slings are not activating, the pops are not activating, etc... When the ball hits the sling or pop it is registering a sound, but not a solenoid. I also placed the ball in the shooter lane and hit the cast button, and it did not shoot.
It seems like everything that requires a solenoid is not working.
#9 2 years ago
Do solenoids fire in the coil test? It sounds like the switch matrix is messed up and so, if bumpers/slings are registering as different switches, it won't fire them.
$ 9.95
$ 119.99
Displays
FlyLand Designs
$ 49.99
$ 5.00
Creekside Hideaway, LLC
$ 8.50
Hardware
NO GOUGE PINBALL™
YouBentMyWookie
$ 9.99
Tacoma, WA
$ 49.00
Pixels Arcade Games
8,999
Richfield, MI
$ 9.99
$ 59.99
$ 60.00
$ 169.00
6,400 (OBO)
Pleasant Hill, CA
$ 220.00
Playfields
$ 24.95
Mitchell Lighting
$ 109.00
Cabinet Parts
Starcade Amusement
$ 1,059.00
$ 109.99
$ 84.99
Displays
FlyLand Designs
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
Watertown, MA
$ 14.95
$ 5.00
Comet Pinball
$ 49.99
This page was printed from https://pinside.com/pinball/forum/topic/weird-issue-with-fish-tales-appreciate-any-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
