(Topic ID: 92013)
Weird Firepower switch issue...please help!
By DnDPins
5 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by cp1610
#1 5 years ago
I have a weird (to me at least) firepower scoring or switch problem which I think is under the playfield. I need some basic troubleshooting help such as what is the difference between a row problem and a column problem. I put a new rottendog MPU 327 and played for a while and all was fine. I then started having a switch column problem which I spoke to Jim at rottendog about and just got a replacement board which is installed. Because of that I think the problem is under the playfield. here are the details:
1) The #6 arrow blinks but when it is hit, you get a sound,but it does not score and the light still blinks
2) All other switches on the same column behave the same way
Here is what I did:
I checked all diodes (in circuit) in the column and each tested within the proper voltages on the band side and null on the other side except the spinner. The spinner tested fine on the band side but was not null on the otherside. I cut one side and tested out of circuit and it then tested null. I went ahead and replaced the diode but still have the same problem.
Am I missing something basic? Remember that I think it must be under the playfield since I have the same problem with two boards.
Thanks,
Dave
#2 5 years ago
Quoted from DnDPins:
Sounds to me like the switch is working from this statement. Do a switch test and see if all register correctly. If they pass the switch test, your problem is likely elsewhere.
#3 5 years ago
that does not sound right. spinner should be no different than any other switch. so one direction .5-.7 other way should be null, OL no reading. is the spinner in same row or column that you are having issue with.
#4 5 years ago
Let me clarify the spinner issue. It does test as expected once out of circuit; .5xxx on the band side and null on other. And after replacing with a new diode, same results so the spinner is acting exactly as the others. Sorry if my prior post was confusing. What I meant by same results was that the row problem still exists.
New Information:
I performed a switch test and none of the switches in that row registered. Does this ensure the problem is under the playfield? How do I troubleshoot it?
Thanks,
Dave
#5 5 years ago
i believe i understood you fine, what i am suprised is that you had to remove one end of that diode to prove it was not bad. it is not like a coil diode in parallel with a coil or short. you get my thinking? if the other switch diodes could test fine and that spinner one doesn't....
#6 5 years ago
Yeah...I hear you CNKay...that is why I replaced the diode. Now the new one acts the same as the others while in circuit. Unfortunately, it did not resolve the issue.
#7 5 years ago
remove the switch row and column connectors off the mpu board and you should be able to jump the row with the column to get that certain switch to register on the switch test, if it doesn't it is the board if it does it is the PF.
#8 5 years ago
New Information:
Thanks,
Dave
Jim sending you a replacement board and the same column having problems is a pretty good indicator that the problem is on the playfield. You need to check continuity between each switch column connection and the CPU board. You likely have an open somewhere on that column.
#9 5 years ago
Check the connector had switch problems myself on my own firepower has factory boards went through the boards only to find the cheap connector was the issue the wire was no longer fully seated in plug. The things were never meant to be pulled more then a few times. 34 years of pulling and flexing the wires are causing it to fail. I've found the very same issue on the dataeast machine I'm trying to get ruining again.
2,250
Denver, CO
$ 99.00
Pinball Sales
$ 14.99
PinballElectronics.com
$ 259.95
Pin Stadium Pinball LEDs
$ 12.00
Siegecraft Electronics
$ 22.00
$ 49.95
$ 48.00
$ 45.00
