Did you check the transformer settings?
Is the high power tapped?
Do you have the correct return springs?
What is the current playfield inclination?
Has the game been recently shopped and flippers rebuilt?
Has the playfield been recently waxed?
What is the comparison to any other titles of the same period and manufacturers you may own?
Ask yourself these questions for initial assistance.
This easier than anything else stated above.
Setting the EoS to open earlier should not be required.
Don't jump to adding unnecessary electronic components that were never recommended or approved from the factory or update bulletins.
If the game has the factory coils, an owner should not need to modify anything.
If you feel the game is still too powerful, elevate the angle of the playfield by approximately 1-1.5 degrees BEFORE modifying the transformer settings.
Don't "fix" things that do not need to be repaired, including lack of math calculations with resistors.
Technicians classify this as a hack, as it rarely restored to the original factory specifications when a game is sold at a later date or something else goes wrong.
My estimate is your game was tapped for higher power from the transformer by a former owner or operator that wanted the flippers to be "hot" due to lack of interest in performing maintenance.
