Had a previous post describing multiple issues. Want to separate the issue here to try and get this one resolved. The ball won't kick out of the outhole to the shooter lane. The solenoid tries repeatedly, but doesn't have enough power to kick the ball all the way to the shooter lane. The coil tests good (as do all the others). I've replaced the TIP102 and 2N4401. I've repinned the J11 connector on the driver board (also the 40 pin interconnect). Have reflowed the solder on the headers. Could a diode on another coil or switch be causing this problem? I can't seem to get the game into diagnostics to do a solenoid test.
The coil fires, just barely a bump....not enough power to kick the ball.
