Seeking the advice of those who know more than me.
One of the pop bumpers on my stern magic is really weak both when activated by the switch, and when activated in the solenoid test.
However when I ground the transistor (by clipping a croc clip to the ground wire in the head box and tapping the other end to the metal tab on the top of the transistor) it fires with normal full power.
I think I have ruled out a switch issue as it occurs in both gameplay and in the solenoid test which is independent of the switch, and it can't be wiring as it works when the transistor is grounded.
Is this just a bad transistor, and should I have a go at swapping it out, or is this a symptom that you recognise as being caused by something else. Thanks in advance.
