Hello all, I have been trying to sort out a problem with my Whirlwind. Two of the kickers are weak, the shooter lane kickout is weak and sometimes struggles to serve the ball into the shooter lane. Also the cellar kicker is weak and sometimes isn't able to get the ball out of the cellar until the second kick after it falls back in. The problem seems to be intermittent, the kicker is always weak but sometimes it will be able to get the ball out of the cellar 7 or 8 times in a row before it has to kick twice to get it out.
The cellar kicker assembly is new (new coil as well) and I have adjusted the alignment so it should be hitting the ball squarely. I checked the wires that go to the kicker coil itself and the solder joints are good. I reseated the wires in the connector for the interconnect board, no effect.
Any ideas where to look next?
