(Topic ID: 181453)
Weak kickers
By Chillyh2o
7 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Topcard
    #1 7 years ago
    I have a 1960 Bally "Beach Queens" pinball and am by no means skilled in working on pinballs but I'm ready to try...any help is appreciated. The problems are the kickers are weak (don't have much kick), but when I push the kickers by hand they work fine. Also the scoring is not accurate. What's supposed to be 5000 points scores as 1000. Thanks in advance.
    #2 7 years ago
    Hi Chilly.
    Don't have that pin, but would suspect dirty/mis adjusted switches, at least.
    Those get gunk in them, and get bent outa shape a lot...
    clean the contacts with a dremel tool with a brass brush, adjust and try it.
    for the scoring, look at the bonus parts, one is not switching between the 1 and 5.
    #3 7 years ago
    Thanks for your quick reply...I hate to sound entirely stupid but are you talking about the switches in the back of the machine or underneath the play field??
    #4 7 years ago
    the ones behind the kickers.
    and the bonus...well... could be anywhere.
    there should be labels on the relays to identify them.
    chk under the play field first.
    #5 7 years ago
    Disassemble the unit and clean or replace the coil sleeves. Polish the coil plunger rod. Make sure the rubber is the right size (not too tight). Make sure linkage components are not rusted or binding, clean and wax/polish. Adjust switch where it is sensitive but not too.
    If all else fails replace coils with a hotter version.
    #6 7 years ago
    Quoted from phil-lee:
    What he said!
    This page was printed from https://pinside.com/pinball/forum/topic/weak-kickers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
