New! Dark mode!
(Topic ID: 208642)
Weak Flippers. What is the cause ? Williams system 7
By pinlink
2 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by grantopia
    #1 2 years ago
    It is not the EOS switch. I have ensured over and over that it is tight and making good contact (pic below). It is opening at 1/8 inch when flipper is fully extended. I even held the contact together and flipped, but the flipper was still super weak.
    So my question is, What else can cause a weak flipper other than an EOS switch. I measured voltage on each lug of the solenoid and was getting about 35V on each lug.
    This problem just started and only at one flipper (lower left). This problem arose afterI was in the backbox, repinning a connector. I have reseated everything with no change. What is causing my flipper to be weak, is there maybe a connection in the backbox that would cause weakness of the flipper?
    #2 2 years ago
    Quoted from pinlink:
    Have you compared how long it takes the linkage arm (or whatever you want to call it) to actually make contact with the EOS switch and open it? It is a similar radius to the right flipper? I have had to make adjustments to the switch position on games because it was taking too long for the switch to actually open compared to the other flipper.
    #3 2 years ago
    Did you also replace the cabinet button switch?
    #4 2 years ago
    Coil sleeve is good and doesn't need cleaned out/replaced?
    #5 2 years ago
    Quoted from grantopia:
    I have compared the two, and it seems the same. Even if the switch never opened though, wouldn't the flipper still be strong? I mean opening the switch just switches it to low power, correct? doesn't effect the strength? (Im asking, I really dont know)
    Quoted from Inkochnito:
    No I have not done that.
    #6 2 years ago
    Quoted from jfre81:
    Just replaced recently.
    #7 2 years ago
    There must be good clean contacts on the flipper button cabinet switches also.
    #8 2 years ago
    Probably poor wording on my part - I would make sure it is not opening too soon and not too far. That's really what I meant by comparing the too. If you have vast spacing differences between the good and bad flipper, see if you can adjust them so they mirror each other. You can also just adjust the switch in and out and see if it's making any difference. If it gets stronger moving the gap and timing one way you probably just need to tinker until it feels correct.
    $ 130.00
    $ 369.00
    $ 40.00
    Arcade Arts
    $ 29.00
    The MOD Couple
    $ 96.95
    $ 9.99
    $ 9.99
    $ 28.25
    The MOD Couple
    $ 65.00
    Cabinet - (Alt) Translites
    Judge Dredd Translite Out of stock
    $ 128.00
    $ 65.00
    Texas Pinball
    $ 14.95
    $ 11.49
    $ 85.00
    Loop Combo Pinball
    $ 9.99
    Bent Mods
    Various Novelties
    Pinball Photos
    Creo Pinball
    $ 50.00
    Back Alley Creations
    Hardware
    $ 159.00
    CzTV Mods
    $ 22.00
    Hardware
    The MOD Couple
    $ 89.99
    $ 24.25
    The MOD Couple
    $ 42.00
    $ 9.00
