(Topic ID: 207747)
Weak flippers on hold
By ChrisLIX
6 years ago
  • 13 posts
  • 7 Pinsiders participating
  • Latest reply 6 years ago by bonzo71
#1 6 years ago
Hello,
I would like to know if this is something normal on my Aztec machine.
The flippers are strong before it reach the up position (so the EOS is open) but become too weak when the ball is coming too fast.
When it happens, the flipper goes down a little until the OES become close which give to the flipper the total voltage. The problem is it give a kick on the ball which is very annoying.
When I bought the machine, the left flipper was doing the "machine gun" so I replace the coil with a brand new of the same model. At the same time I decided to replace the right too to get exact performance on both side. Now, no more machine gun, but this trouble.
I measure the voltages and get the same value for both side : 29.2V EOS close and 8.2V on hold (EOS open).
Flipper are buzzing too on hold sometimes but I don't think it's related to the weak problem and I could live with that.
I recorded a video to show you what happens :
Thanks for your comments/suggestions
#2 6 years ago
Some dip is normal on games with AC flippers. All you can really do is gap the EOS closer. That drop does look a bit more than I'd expect but not a ton
Buzzing is inevitable too.
#3 6 years ago
Thank you I will reduce the gap so.
#4 6 years ago
Not a bad idea to fit new EOS switches and flipper cabinet switches too. That way, max voltage is present right through the chain.
#5 6 years ago
Quoted from Vintage-Pinball:
Thanks, you think my values are too low?
#6 6 years ago
Without a schematic, I don't know what the voltages should though I thought WMS machines of that era used 24v AC [ used to be 50v on earlier games] You might want to look at Pinrepair as I'm sure there is, or was anyway, a list of coils values, measured by resistance rather than voltages.
My point was though that from experience, Its a good idea to replace all the electrical switches that feed up to the coils. And, you might want to check your coil stops and flipper plunger to make sure they are good. Again, I prefer to change the lot if they look worn.
#7 6 years ago
Change the coil stop. When the coil stop becomes magnetic the hold gets weak and you get the recoil you describe. A good part of the hold is due the plunger magnetically attaching to the coil stop. Once the coil stop itself becomes magnetic this doesn't seem to work all that well anymore and it weakens the hold.
#8 6 years ago
Actually, the kick that the flipper is imparting to the ball is typically a result of the EOS gap being too small when the flipper is all the way up.
What is happening is that the momentum of the ball is causing the flipper to bend downwards slightly (completely normal) to a point where the EOS switch contacts re-enagage and the low-power side of the coil is short-circuited, which then causes the high-power side of the coil to force the flipper back upwards. This effect pogos the ball off the flipper bat. What you want to do if the pogo effect is excessive is to re-gap the EOS switch so that it opens sooner, and thus has a larger gap when the flipper is at the end of its upward travel. However, you don't want to open the gap too far or you will lose power on the flipper up stroke: it's a trade-off.
#9 6 years ago
Thanks guy, I will take a picture of the coil stop to show you if I should replace it.
#10 6 years ago
Here are two pics of the coil stop and one of the coil plunger.
#11 6 years ago
I think replace that Stop, and I agree with trying the larger eos gap, post results!
#12 6 years ago
PBR sell rebuild kits which include the stop, spring, plunger, sleeve, etc. Well worth doing
#13 6 years ago
To me, the pbr mini kit is overkill and was designed to make $ on the uninformed. You can buy the stops, springs, plunger/links, sleeves and bushings for $22. The kit will cost you $36..you'll get some extra stuff like eos switches and screws, but those are usually unnecessary.I never buy the springs either since they are usually ok or an be given a bit more resistance by stretching them a bit.
Beehive Pinball Co.
Ashburn, VA
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/weak-flippers-on-hold and we tried optimising it for printing. Some page elements may have been deliberately hidden.
