(Topic ID: 249905)
Weak flipper on TAF - inconsistent
By arolden
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by arolden
#1 4 years ago
Hi everyone
Having some issues troubleshooting the bottom right flipper on TAF. Flipper assembly is in good condition. Wiring all seems OK. Fliptronic board has been rebuilt by someone in the past - probably to fix this problem. All other flippers are fine.
The right flipper will sometimes lose the power stroke and will only flip with hold power (too weak). When I first came across the issue I lifted the playfield to look at the flipper assembly and it started flipping at full power again as soon as the playfield was half raised. Weird.
The next day it was weak again. I'm thinking some wiring was getting pinched or the coil was improperly soldered but the wiring checked out OK. Any ideas on why it would intermittently lose the power stroke?
Connector issue? Bad solder joint? Thanks for any tips.
#2 4 years ago
Could me a multitude of things so start with the simple stuff first. Check the fuse, connectors, soldier points, and coil winding. Then trace the wires to check to make sure nothing is pinched or stressed. Check the flipper leaf switches to make sure they are not fouled or worn out. Continue from there.
#3 4 years ago
Finally fixed this issue. It was the Fliptronic board. The TIP36 and TIP102 transistors for the power winding had been replaced and tested good. But nothing further down had been replaced. Turns out that diode D8 had failed. That was the problem component after all.
20,000 (OBO)
Oakdale, CA
26,000 (OBO)
Auckland, NZ
$ 55.00
Twisted Tokens
$ 84.99
GMods
11,000 (OBO)
Hanford, CA
$ 24.00
Various Novelties
Pinball Photos LLC
$ 399.00
$ 9.99
$ 9.95
Twisted Tokens
$ 31.99
Lee's Parts
$ 19.99
Mitchell Lighting
$ 29.95
$ 24.00
Various Novelties
Pinball Photos LLC
$ 41.99
Lee's Parts
$ 1,159.00
$ 329.99
YouBentMyWookie
$ 29.00
Pinball Photos LLC
$ 180.00
14,500
Pleasant Hill, MO
$ 29.99
NO GOUGE PINBALL™
$ 9.95
$ 1,059.00
$ 26.99
Lee's Parts
$ 45.00
Twisted Tokens
Avid Creations Wireforms
This page was printed from https://pinside.com/pinball/forum/topic/weak-flipper-on-taf-inconsistent and we tried optimising it for printing. Some page elements may have been deliberately hidden.
