The right bottom flipper on my Shaq Attaq was weak, I could never get enough speed to get the shots in the basket.
So I rebuild the coilstop, sleeve, plunger, spring and the other plastic thing that the flipper runs through from the playfield down to the flipper-mechanism itself.
But it's still sluggish and cant make the basket-shot.
So what else could be wrong here?
The coil is the correct one as printed next to it. Could it need a stronger coil anyway?
Does anything else needs to be replaced as well? Could the actual flipper be bent or something and needs replacement?
The bottom left flipper is ok in every way, stronger and makes the basket shot without any problems.
