Right flipper works, but with very little power to move the ball. I replaced the whole flipper assembly, but no help. What else can I look at? Does button assembly have anything to do with it? Thx
Quoted from a0m82zz:I replaced the whole assembly. No difference. Thoughts?
Define whole assembly please.
It came as one unit.
Added over 4 years ago:Why does spark on eos switch good sometimes and weak other times?
Be sure the high voltage flipper button switch is super clean and aligned correctly.
Then be sure the EOS opens as late as possible in the swing
First of all, thank you for responding. I'm gonna send you a picture of leaf switch by button in a few minutes. Stand by.
Quoted from a0m82zz:First of all, thank you for responding. I'm gonna send you a picture of leaf switch by button in a few minutes. Stand by.
If the flipper is moving at all, by default it is working. You need to determine if the power is flowing through the coil and EOS correctly.
This page was printed from https://pinside.com/pinball/forum/topic/weak-flipper-on-amigo-em-machine and we tried optimising it for printing. Some page elements may have been deliberately hidden.
