So the left side is the ufo shot and if you shoot to the right , through the monster, you enter the backboard shot which represents the rollercoaster ride from the movie and extra ball will be collected there,but only when you have all 4 yellow targets lit.
That is the plan for now.
We owned a " jolly park" from spinball a few months back...that inspired us for the acrylic layer over the artwork.
Simply indestructable
Have you tried using a jigsaw plastic cutting blade for the plastic? It should make it easier and cut clean lines. You can also use the dremel sanding barrel bits to trim it further.
You guys are soooo committed. Or you should be committed. Can't decide.
Such a fun thread and you are entertaining people all around the world. Awesome stuff.
Quoted from jokerpoker:You guys are soooo committed. Or you should be committed. Can't decide.
LOL we are for sure balancing between the two
Ironically, our second machine will be "Crazy Mansion" and indeed inspired by an insane asylum.
So i am afraid we bend to the crazy side a little..
Quoted from Bonnevil69:Just out of curiosity, How long did it take to cut that acrylic?
I bet we spend a good hour on it,this acrylic cracks easily in the wrong direction and it is ruined.
So we took our time,slowly.
Acrylic/plexi cuts very easily with a hand held jigsaw. They sell blades specifically made for acrylic, but a metal blade works fine too. The trick is to clamp it and keep downward pressure so it doesn't jump around. I have an art framing business and usually use the table saw and a composite blade for square cuts. The edges sand down by hand pretty quickly to get it to a point where you can polish.
Quoted from dookski:Acrylic/plexi cuts very easily with a hand held jigsaw. They sell blades specifically made for acrylic, but a metal blade works fine too. The trick is to clamp it and keep downward pressure so it doesn't jump around. I have an art framing business and usually use the table saw and a composite blade for square cuts. The edges sand down by hand pretty quickly to get it to a point where you can polish.
Ok thanks for the advise,we want to make a big acrylic sheet for the big playfield too, so we will use your advise.
We want the playfield to last,our jolly park pinball was still in excellent shape after all these years.
Quoted from pinballrockstar:Ok thanks for the advise,we want to make a big acrylic sheet for the big playfield too, so we will use your advise.
Why not clear coat? I think acrylic will scratch very easily?
Quoted from tezting:Why not clear coat? I think acrylic will scratch very easily?
We have gble, if stern can't do it right, we will screw up for sure.
Quoted from pinballrockstar:We have gble, if stern can't do it right, we will screw up for sure.
Haha point taken!
Quoted from Bonnevil69:If you have cell cast acrylic available it's much easier to machine and cut
We bought this sheet at the hardware store, we vacuum form it, saw and cut it.
Quite expensive but not the best stuff out there.
What is the retail name for cell cast acrylic?
Never heard it called anything but cell cast so don't think it has brandings like extruded acrylics do
Quoted from pinballrockstar:We bought this sheet at the hardware store, we vacuum form it, saw and cut it.
A lot of the material I get for framing is this Arcylite brand, most often OP3. Your regional distributor will probably only sell directly to you if you have a resale certificate, but you can buy the material from an art framer or some other type of fabricator at retail too. They will probably cut to size for you at minimal cost.
I pay a little less than $3.50/sq.ft. for OP3.098 (about 1/8" thick). You might not need UV filtering stuff.
Using sharp tools and moving slow you should be able to drill and cut it however you want.
http://www.acrylite.net/product/acrylite/en/products/acrylite/uv-filtering/pages/default.aspx
Oh yeah check out that link- OP2 is the cast stuff. Might want to do some other google searches as there is a lot of other info out there.
There are two types of transparent/clear acrylic. Cell Cast and Extruded. Cell Cast is made by pouring liquid plastic between two sheets of glass. Extruded is made by heating plastic and pushing it through a slit. The result is different cell structure and at least for me (I do vacuum forming) the Cell Cast cannot be vacuumed formed (Well maybe in a big dome)...at least not in detail. So if I want to vacuum form acrylic it must be extruded.
Your will find lots of colors in the Cell Cast and limited colors (and availability) in the Extruded. Any plastic store/supplier knows (or should know) the difference. There is a store here in Seattle that sells acrylic and the colors are only Cell Cast and their clear is only extruded.
Quoted from dookski:Oh yeah check out that link- OP2 is the cast stuff. Might want to do some other google searches as there is a lot of other info out there.
Quoted from Freeplay40:There are two types of transparent/clear acrylic. Cell Cast and Extruded. Cell Cast is made by pouring liquid plastic between two sheets of glass. Extruded is made by heating plastic and pushing it through a slit. The result is different cell structure and at least for me (I do vacuum forming) the Cell Cast cannot be vacuumed formed (Well maybe in a big dome)...at least not in detail. So if I want to vacuum form acrylic it must be extruded.
Thanks guys,very useful !
+1 for Arcylite. the other thing to look into is once you have everything measured correctly, getting the pieces laser cut which would give you precise, clean lines and a perfect fit.
I've been using ponoko.com. I believe that they have a couple of locations in europe, so everything could be cut and shipped within your region and the costs pretty reasonable
Quoted from j_m_:+1 for Arcylite. the other thing to look into is once you have everything measured correctly, getting the pieces laser cut which would give you precise, clean lines and a perfect fit.
Yeah, to manually do this really stinks, we need a laser!
Quoted from pinballrockstar:Yeah, to manually do this really stinks, we need a laser!
get lapnip to send you one. he's rich, he can afford to!
Quoted from j_m_:get lapnip to send you one. he's rich, he can afford to!
ha
i could offer this for a little labnip catnip
Quoted from labnip:ha
One is rich if he owns a minion madness pinball
This page was printed from https://pinside.com/pinball/forum/topic/we-are-building-a-minions-pinball-updates-every-friday/page/30 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
