Quoted from CUJO:Actually I ran a ALL LAMPS TEST this AM and one whole ROW is out indicated on the LAMP MATRIX chart.
That would be ROW 8:
Washington "R", Strength (Ball), Skill (Ball), Ultra Spinner (2), Right Flipper Lane, Upper Left Lane, Left Ramp Buy Tickets & Skill Shot Center.
Ok so you said row 8 and and listed all the lamps in row 6 so I am going to go with Row 6.
Row 6, solenoid 14 (Right Eject Hole), and Solenoid 6 (Trough) are all controlled by data bit 5 and these are the only things on the power driver board that are controlled by this bit so logic would tell us that your problem is a result of an absence of this bit. Most likely cause would be bad ribbon cable between the CPU J211 and power driver board header J113. This could also be a problem with the solder connection to the header pin on either board MPU J211 pin 19 or power driver board J113 pin 19, or a cracked trace on either board.
If you haven't already tried flipping the ribbon cable around, go ahead and try that first to see if the problem remains, changes, or goes away. If the cable is bad, I would expect to see a failure or row 8 lamps, solenoid 8 (Ramp Diverter), and Solenoid 16 (Diverter Hold) as the problem would migrate to data bit 7.
On the power driver board, you should be able to buzz the connection for data bit 5, it goes from J113-19 to the following points:
U11-2
U9-4
U2-14
U3-14
U4-14
U5-14
Good luck!
