(Topic ID: 91913)
WCS94: Lamp Matrix Row 6 & Column 6 Are Out
By CUJO
  • 38 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by ChrisHibler
#1 4 years ago
All of a sudden all of Row 6 and Column 6 are out. Bulbs are good.
Reseated J134 & J135. Also Reseated J138. No good.
Pin starts and plays fine but having 15 lights not working isn't fun.
Anything I can check?
I have checked wires going into the connectors, all good.
I tried to check Q85 & Q93 on the driver board after pulling off J134, J135 and J138.
Does the black lead go in the top of the transisitor heat sink hole or the red probe in MM diode test mode?
Should I test Q85 and Q93 the same way? Did I pull off enough connectors to test the transistors properly?
#2 4 years ago
Has the driver board been worked on previously?
Especially examine the right most 20 pin IC in the row with U1, U2, etc.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#3 4 years ago
Quoted from ChrisHibler:
Yes, about a year ago by CoinOp Cauldron.
But I had shorted a #44 bulb base against a switch lug when putting in LED's/
What am I looking for on the IC? Burn?
#4 4 years ago
Clive is a good tech, and I don't know the history of the board.
But I do know that the data lines pass from component side to solder side by way of the through holes on the right most IC in that row. "Buzz" the traces to ensure that D5 is getting to where it needs to.
I don't have the schematics with me or I could give you a better idea of where to look.
#5 4 years ago
Clive is a great tech. This is my fault what happened.
I tried to put LED's in the game with the power on ever so carefully. And just a tiny little spark when the #44 bulb base brushed a lug to a switch I guess as it drooped while I was grabbing a bulb to insert.
Well, look how that turned out...Never again...I knew the risk..and still did it.
I pulled the WPC Driver board and started testing transistors.
All 8 of the transistors above J137 connector are testing blown for starters.
I also noticed that the trough kicker solenoid wasn't firing either.
It was working after the short because I played several games on it, then it quit.
#6 4 years ago
Quoted from CUJO:
Agreed...and to be clear to the casual reader...when I mentioned the board history, I meant =before= Clive saw the board.
All 8 transistors testing bad doesn't sound right. I suppose it's possible, but unlikely.
A logic probe would help considerably. You can track the signals across the board.
#7 4 years ago
Logic Probe? Beyond my tool kit..lol
I used the PinWiki method of using diode test on those 8 transistors and they measure all open.
Put black probe on center lug and test both outside lugs with red probe, I get no meter movement.
Put red probe on center lug and test both outside lugs with black probe, I get like .563 on one side and .493 on the other side on all 8 transistors.
This is for Q91 thru Q98...
#8 4 years ago
Quoted from CUJO:
That is a normal reading for that particular kind of transistor.
The issue lies elsewhere.
#9 4 years ago
possible broken wire, bad connection in one of the connectors?
#10 4 years ago
So is this all I can do with DVM at this point without a logic probe?
All the TIP-107's on the WPC Driver board test ok. Q85-Q93
And all the TIP-102's test ok. Q83-Q90
Tell me again how to 'buzz' d5 ? Continuity check?
#11 4 years ago
Can anyone recommend a reasonably priced logic probe for testing?
#12 4 years ago
Logic probe should be 20-30 bucks. Nothing super fancy about them..
ebay.com link » Logic Probe 72 415 Tenma
This one has a pulser, which is useful sometimes
ebay.com link » Logic Probe Pulser
#13 4 years ago
Quoted from johnwartjr:
Thanks! Any guidance on how to test with these for my issue?
Is there a tutorial somewhere?
#14 4 years ago
You need to "buzz" D5 across the board.
D5 comes across the ribbon to U1, pin 14.
It provides the lamp column and row enable signals for column/row 6.
Try this...with the game on, in lamp test, press on U5 firmly.
If that "fixes" the issue, you have a damaged through-hole at U5, pin 14.
If that doesn't work...
You should be able to buzz from U1, pin 14, to
U2, pin 14
U3, pin 14
U4, pin 14
U5, pin 14
U11, pin 2
U9, pin 4 (corrected)
Game off, of course.
It's best to remove the driver board as you'll need to repair it anyway.
Somewhere between all of those pins, you'll find a discontinuity. Then it's a matter of finding the fractured through-hole or trace.
#15 4 years ago
U2, pin 14
U3, pin 14
U4, pin 14
U5, pin 14
U11, pin 2
U19, pin 7
The board is out of the game now anyway.
I'll pick up a logic probe at Harbor Freight or Radio Shack tomorrow if they have one and report back.
#16 4 years ago
Quoted from CUJO:
You "buzz" between connections with a DMM set to "continuity".
#17 4 years ago
This one looks pretty good for the dough..
ebay.com link » 1pc New Logic Pulser Ttl Analyzer Probe Circuit Tester
#18 4 years ago
Quoted from CUJO:
It does, but I'd rather spend another $10 to get one from American soil, as it'll get here quicker, and it's easier to return/exchange if there are problems with it.
#19 4 years ago
I own a Klein Tools MM200 MM. Can't I put it in continuity check with audio and "buzz" the test checkpoints?
Or does the logic probe offer something else I just haven't learned about yet, at least for this test?
#20 4 years ago
Yes, use the MM to test continuity, see Chris's post, he is suggesting that the solder point, or through hole is loose or damaged, and likely the source of your issue, so make sure you test as he has outlined first, press that connector in, or wiggle to see if the lights come on.. this will tell you if you have a solder or through hole issue.
#21 4 years ago
For the tests Chris suggests, even a $10 multimeter would suffice. No need for a logic probe to test where he is sending you, which is a valid first path.
Chris is a solid tech.. have no fear
#22 4 years ago
U2, pin 14 - Yes
U3, pin 14 - Yes
U4, pin 14 - Yes
U5, pin 14 - Yes
U11, pin 2 - No
U19, pin 7 - No
Hi Chris!
Here's what the tests revealed.
See above.....
#23 4 years ago
Quoted from CUJO:
Hi Chris!
See above.....
Yup. I've seen that before, but couldn't find the prior RGP post where I discussed it.
U5 must have been replaced at one time, and the trace on one/both sides of the board at U5 pin 14 were damaged.
You might get lucky, if you have a good slender iron, by reflowing the solder around that leg just a touch to re-establish the connection. Buzz with your DMM to measure success.
If that doesn't work, then if the tech did NOT use a machine pin socket when replacing U5, the proper course of action is to remove the socket, clean up the damage, and install a new socket.
If a machine pin socket was used, it's best to not attempt removal. The traces are very fragile and have already been damaged. Use a small jumper to connect U5 pin 14 to U11 pin 2 on the solder side of the board.
That should get you going again.
BTW, Thanks JWJ!
#24 4 years ago
Yup. Call it a good guess, or whatever, but that's what I thought we'd find.
BTW, Thanks JWJ!
Wow! Good call!
I reflowed the solder on the solder side of U5-Pin14 and I get the "buzz" now at U11, pin 2!
The bad news is that I still do not get a "buzz" at U19, pin 7.
Thanks!!!
#25 4 years ago
Quoted from CUJO:
Wow! Good call!
Thanks!!!
Whoops. My bad. Typo or late night schematic reading.
I should have said U9 pin 4. Try that.
I bet you're good to go now.
Original post corrected.
#26 4 years ago
No problem Chris.
U9 - Pin 4 is buzzing.
Gonna pop the WPC Driver Board back in the backbox.
Will let you know how it goes.
THANKS!
#27 4 years ago
Hi Chris..
Well good news and some bad news after installing the WPC driver board back in and powering up.
The Good News:
All the previous lights that were out are now working! Yea!
However now 5 totally different ones are out...
All are in Column 3 of the Lamp Matrix:
These 5 are now out:
Ultra Goalie (PF) - 33
Ultra Ramp (PF) - 34
Spirit - 35
Skill - 36
Right Ticket Half - 37
Update:
Reseated the connector on the PCB light board under the playfield and the 5 lights came back on!
Might need to reflow solder on the pins on that board if it keeps losing connection.
Dang these old pins can get finicky!
Thanks again for your help Chris!!!
#28 4 years ago
Quoted from CUJO:
Definitely reflow them. That's SOP for WPC lamp boards...although this is in the S11 section.
http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#Lamp_Boards
#29 4 years ago
WCS94 is holding up well now. All lights are a go! I couldn't believe how simple the fix was and how you
dialed it in Chris! Game is so much more fun now with all the lights working! You help was greatly appreciated!
#30 4 years ago
Thanks for the feedback Cujo...enjoy the game!
#31 4 years ago
Dang it! Spoke too soon..
All the lamps in Column 6 on the Lamp Matrix just died while playing tonight.
However this time, all Row 6 lamps are all continuing to work OK except the UPPER LEFT LANE bulb 66 where column 6 and row 6 criss cross on the lamp matrix chart...
#32 4 years ago
Ya...that still has to be a marginal solder joint.
#33 4 years ago
I'll touch it up again. I reflowed it on the component side of the board only before, then buzzed it successfully.
So I left well enough alone and never touched up the solder side.
If it doesn't hold, I'll run the jumper wire as you suggested earlier on the solder side.
Update: I notice when I first turn on the game the column 6 lights all work for about 3-4 minutes before going out together. This happens on attract mode too.
So Buzz U1-14 to:
U11, pin 2
U19, pin 7 ?
and correct it with reflow or jumper wire?
#34 4 years ago
Pic of jumper wire added from U5-14 to U9-4
7 months later
#35 4 years ago
Old threads continue to pay dividends... Similar issue turned up here except a different data line. One jumper later the matrix is good again!
-Rob
-visit http://www.kahr.us to get my daughterboard that helps fix WPC pinball resets
#36 4 years ago
Quoted from rkahr:
-Rob
Rob,
Which data line was it for you?
#37 4 years ago
D6. All was good at York but the row and column have been out since I got home. Finally had some time to poke around this weekend and one jumper later all are happily blinking on cue again...
-Rob
#38 4 years ago
Thanks Rob. I'm positive that D5 moves from one side of the board to the other via an IC through hole as I tracked down a faulty solder joint causing row and column 5 to not light. I'll have to look at D6 too.
San Diego, CA
PinSound
$ 47.00
Gweem's Mods
Fullerton, CA
Flashinstinct
Aliso Viejo, CA
3,200 (OBO)
Menomonee Falls, WI
PCB Emporium
$ 40.99
Lee's Parts
$ 225.00
Professor Pinball
$ 50.00
$ 229.99
$ 11.95
$ 159.99
$ 66.95
KAHR.US Circuits
