first just want to say that maybe I'm over thinking this one and I haven't spent a good hour under the hood trying to figure out the issue I'm having with these WCS94 flippers.
I put a new fliptronic 2 board in, as the original was missing.
I also noticed that a diode was missing on the left coil (replaced the diode correctly) while the right coil is new. Both are the correct coil sizes.
I noticed the right coil was new/replaced but would not ''hold'' and noticed the left wire had come off the left lug of that coil- replaced and it holds now.
What I can't figure out, and I don't remember experiencing this in the past, is why there is a subtle ''pull'' at end of stroke that pulses. You don't really notice this while in game, but if you lift the playfield you can see it pulsing slightly, glass of and with nothing going on, you can hear the pulsing too, it's slight.
I'm thinking eos? But I replaced both with new and they are open and gapped correctly, along with new coil sleeves and stops. My solder on the lugs looks well too.
In game it will make strong shots and other times it will make half limp shots. Any ideas? I have cleaned the flipper opto switches as well.
I feel like my bases are covered but I'm going hmmmm for the moment
thanks
