(Topic ID: 294157)
Wcs wizard mode Problems
By rx2006je
2 years ago
  • 67 posts
  • 12 Pinsiders participating
  • Latest reply 2 years ago by rx2006je
There are 67 posts in this topic. You are on page 1 of 2.
#1 2 years ago
I am having some sort of issue when I enter the World Cup final Los Angeles match. When I shoot the final draw to start the match a ball comes into the shooter lane. I shoot that ball and then the one comes out of the final draw. Then another ball loads into the shooter lane. I don’t shoot it because I like to play with 2 balls then another ball loads into the lane until all of the balls are in the shooter lane. It isn’t supposed to do that. What can I do to fix that. All other aspects of the game seem to be working with no issues.
Any help is appreciated
#2 2 years ago
Pretty sure your game is acting normally.
I guess I’d make Sure the shooter lane switch is working?
#3 2 years ago
Quoted from CrazyLevi:
The shouldn’t load ball after ball without shooting one. It is stacking all of them in the shooter lane and you can’t clear it because there are 3 balls in the lane. I will check the switch and see if it is working but if it weren’t wouldn’t it keep loading balls at the start of a game or when you start final draw for regular multi ball?
#4 2 years ago
If you are experiencing ball count problems it can likely be only two things: The trough optos/switches, or the shooter lane switch. Those are the only things that keep track of balls in the game.
#5 2 years ago
I have a video I will upload. The shooter switch works as it should in the test mode and all opto in the trough are working as they should.
#6 2 years ago
Are you sure there’s something wrong with the game?
I’m pretty sure I’ve had a couple balls back up in shooter during that wizard mode. Maybe there’s a vid of it online you can compare with.
#7 2 years ago
Something is making your game think a ball drained.
Go into test, leave a ball in the shooter lane, and start pressing switches until you find out what it is. You may have a broken diode or something.
#8 2 years ago
No...physical lock switches also keep track of balls.
#9 2 years ago
Quoted from dsuperbee:
How many does this game have?
Pretty sure it’s zero! One ball gets diverted by the magnet. The other is in play the other sits in The trough.
#10 2 years ago
2 actually, on the mini upper pf.
#11 2 years ago
Well, check those!
#12 2 years ago
Here is the video
https://drive.google.com/file/d/1SaSSMqCnpeuFGN6yZwwkgndtwmpDPNyS/view?usp=sharing
not sure what you mean by 2 physical locks on the left mini playfield with the maganet
#13 2 years ago
Have you done a switch test yet?
#14 2 years ago
are you testing the shooter lane switch with a pinball, or you finger? make sure a ball sitting in the lane triggers it, not just that it's functional.
#15 2 years ago
Quoted from bigehrl:
With a ball sitting in the lane it closes. What is weird is that it only happens in wizard mode. If you get the striker multiball then it doesn’t do it. Nor does it try and launch balls continuously when you start a game or enter final draw.
Yes I did a switch test I will do one and upload a picture to show you what I am looking at in the switch test if that will help
#16 2 years ago
Quoted from rx2006je:
Post it.
If possible, post a pic of the shooter lane switch too, making sure you captured how it is wired up, and you can see where the banded side of the diode is.
#17 2 years ago
Here are the switch test photos one with the ball our an one with the ball in the lane
FBB69DB2-81B9-4E09-B892-6D03F589DDAA (resized).jpegFBB69DB2-81B9-4E09-B892-6D03F589DDAA (resized).jpeg63AA1361-ED3A-4531-A06F-9139C89C6E9A (resized).jpeg63AA1361-ED3A-4531-A06F-9139C89C6E9A (resized).jpeg4E0503EB-A9C7-43F5-9EF0-B1820AB0D987 (resized).jpeg4E0503EB-A9C7-43F5-9EF0-B1820AB0D987 (resized).jpeg407303CD-C5C9-4004-88CF-ADB194EA41D8 (resized).jpeg407303CD-C5C9-4004-88CF-ADB194EA41D8 (resized).jpeg7B557574-819A-4161-A661-9683462B2251 (resized).jpeg7B557574-819A-4161-A661-9683462B2251 (resized).jpeg
#18 2 years ago
Looking between the 2nd and 3rd pic of your switch matrix, you have two switches closed by the shooter lane.
Start looking for a shorted or bad diode.
#19 2 years ago
Looking between the last and second to last pic, you have two switches closed by the shooter lane.
The one that is 2 above the ball shooter lane? The ball shooter lane works as it should.
#20 2 years ago
Nevermind, i see why the switch in the trough changed.
Sorry to send you on the wrong path.
You cpuld always try a factory reset and see if that clears it.
#21 2 years ago
In your pics, trough switches 1-3 show closed, which means no balls for optical switches. Trough switch 4 (4th switch down on 4th column) shows open, meaning a ball is blocking that opto pair. Gravity shouldn't allow that to happen.
You either have bad trough optos or a worn trough causing balls to not roll all the way down to trough switch 1.
#22 2 years ago
Quoted from phishrace:
this is a common issue on this generation trough design. i'd remove the trough and clean/light sand it. and/or a quick fix is to get one of those plastic trough shims that are readily available. those help.
#23 2 years ago
Thats what i thought....but the optos for the trough are on the 3rd column, not the fourth
The open opto switch is for the goalie.
#24 2 years ago
I have a plastic shim in it
#25 2 years ago
OP, what was the state of column 3 in the photos? The switch matrix indicates 31-36 are optos and your photo 1 shows 31-35 open (ball present) and 36 closed (no ball present). Photo 3 shows switch 35 (trough 5 left) changed state. Is that an accurate representation of what it should show i.e. is the game showing balls where they were when you took the photos?
#26 2 years ago
While in switch edges test, wiggle each trough board connector. If any switch triggers, rebuild both female connectors and closely inspect both trough board male connectors.
If nothing triggers, with 5 balls in the trough and still in switch edges test, smack the trough assembly a few times with the handle of a screwdriver or your fist and see if that triggers any switches.
The female connectors, especially the outside one, are always suspect. A cracked leg on any of the 12 optos (24 LED legs) on the trough board can also cause what you're seeing. If the boards are original, remove them and inspect them closely (if you haven't already).
#27 2 years ago
Quoted from YeOldPinPlayer:
Game was showing where balls were. I had 4 in the trough and one on the shooter lane
#28 2 years ago
I tried wiggling the connectors and nothing skipped out. I tried knocking the trough and nothing went off. The opto boards are replacement boards. I do have the originals as well but when I got the game I was having a trough issue and replaced the opto boards. The issue turned out not to be an opto issue. I have noticed however that when launching a ball that sometimes the optos on the coin toss do not see the ball. Could that be related or a separate issue. Sometimes they do and sometimes they don’t. I see them in the switch test as being closed in column 5 like they should. I need to put something in front of the sensor to test it.
#29 2 years ago
Any optos working intermittently makes all the other optos in the game suspect. Games don't like when switches are intermittent and will sometimes put too many balls in the shooter lane, like you're seeing.
Should be able to test the skill shot optos with a finger or big standard screwdriver. Try vibration in that area while in switch test too.
How do the switch matrix connectors on the bottom of the CPU board look? Rebuild connectors if either look flakey. Also closely inspect the 10 opto board under the playfield. Any bulging capacitors or flakey connectors? If all looks okay, reseat all the connectors.
#30 2 years ago
You have a colordmd correct?
You may have a bad cap for the 12v, especially if you have a color dmd (and if you have a kahr board).
Have you tested your 12v? What did it measure?
#31 2 years ago
All optos work in the switch test using a card to block the beam. I tried banging on the area and wiggling that switch and nothing went off. Not seeing any bulging capacitors and connectors all look good.
Can someone conform that during the final match with Germany that you launch a ball then the one comes out of the final draw scoop and then one enters the shooter lane and waits for me to shoot it. I score a goal and another ball enters the shooter lane even though one was in the lane already. It should load another ball and doesn’t continually load balls like mine is doing. Just want to verify.
I just find it odd that the only time it tries to keep loading balls in the trough is during he final mode.
#32 2 years ago
Can someone conform that during the final match with Germany that you launch a ball then the one comes out of the final draw scoop and then one enters the trough and waits for me to shoot it.
That is correct, but again, you aren't using the correct wording. Launch ball, ball exits scoop, then ball ejects from the trough into the *shooter lane*. Shooter lane switch is very different than trough switches. Please use the correct terms.
The advice above to check the 12 volts is good advice. Didn't notice you have a colordmd.
#33 2 years ago
Ok I understand about the terms. I have a multimeter can someone tell me where and how to check the voltage.
#34 2 years ago
Replace the pinballs with standard shiny carbon ones. See if that fixes the issue.
Your balls may be magnetized.
There should only ever be one ball in the shooter lane at any point during final match wizard mode.
Unless all 5 are in play obviously.
#35 2 years ago
This vid show should help.
#36 2 years ago
Quoted from chuckwurt:
They are new regular balls are carbon balls different. If they were magnetized wouldn’t that cause the issue on any ball launch?
#37 2 years ago
Yes. But it would be also intermittent.
#38 2 years ago
Voltmeter broke I will get a new one and test it Wednesday night.
#39 2 years ago
Do you think it could be a rom issue? Is this an aftermarket rom?
A3E872CC-8CB0-44B4-B6AF-6158888D3A4F (resized).jpegA3E872CC-8CB0-44B4-B6AF-6158888D3A4F (resized).jpeg
#40 2 years ago
Highly unlikely.
#41 2 years ago
New volt meter and tested all parts and everything checked out fine.
#42 2 years ago
What did your 12v measure at?
#43 2 years ago
Here are the voltages
18v=16
12vR=12.15
12vU=14.4
5v=5.2
#44 2 years ago
Have you tried a factory reset, as suggested above? If not, give it a try. Also couldn't hurt to reset both ends of the ribbon cable that goes between the CPU board and driver board.
#45 2 years ago
next on the list to try. Don't want to lose all my scores but oh well, I will give it a go.
#46 2 years ago
Tried a factory reset and a rom change. Still no change in the game. Still putting out multiple balls in the shooter lane during the final with Germany. Not sure where to go from here. Any thing else to try?
#47 2 years ago
You may want to try setting up the issue in switch test and see if something is throwing a switch error, causing a problem with the optos.
If you have another game (or access to one) that uses the same opto board under the pf, you can swap that out and see what happens.
#48 2 years ago
Cut the pink crimp on connector off of the shooter lane switch and solder the green wires onto the middle terminal.
#49 2 years ago
Quoted from GRUMPY:
That switch is wired correctly
#50 2 years ago
I think he wants to make sure the connection is solid.
Pinball Invasion
Playfield - Plastics
$ 17.50
$ 11.95
KAHR.US Circuits
Plantsville, CT
$ 49.99
4,300 (OBO)
Balt, MD
$ 41.99
Lee's Parts
$ 63.95
$ 259.99
$ 29.99
Pinball Shark
Lafayette, LA
Professor Pinball
$ 8.50
$ 26.95
Pinball Pimp
$ 65.00
$ 329.99
€ 69.00
Multiball mods
$ 9.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/wcs-wizard-mode-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
