Quoted from sullivcd40:Yes, the wiring attached to the center lug is yel-blu. In test the left flipper power test fires the flipper normally, no double firing. The left flipper hold test does nothing. The right flipper power test fires the flipper normally. The right flipper hold test makes an audible buzz and moves the flipper slightly. The solenoid only double fires once during gameplay, it does not machine gun. The left flipper worked well until I snapped the tightening bolt today and had to rebuild it. I had to remove the big connector on the board next to the left flipper assembly to get access to the screws.
Side note, if you’re torquing it so much that the bolt snaps, that’s too tight. It requires some force, but not Hulk strength!
The upper flipper opto is just because they only have one type of flipper board, Williams wasn’t going to order new boards for a few games that didn’t have an upper flipper. Post a picture of your cabinet switch just for the heck of it.
I still feel like it’s probably a physical issue, such as the hold winding. I had a wire break on my WCS and we had a heck of a time figuring that out because it actually worked with the playfield up, but not with it down. Broken wire on the backside of the coil against the bracket.
