(Topic ID: 213080)
WCS Fuse 116 soccer ball motor board problem
By maddog14
6 years ago
#1 6 years ago
Yes, I have researched the issue, no I did not find a solution yet. World Cup Soccer 1994
Here is the problem: The F116 fuse blows after a few moments of actual game play. In test mode, all of the 12 volt motors work with no apparent issues. If I unplug the 12 volt motor for the soccer ball from the motor controller board, I no longer blow the fuse. The voltage to the motor is 14.4 volts.
While I do not have a spec for the chips on the controller board, nothing diode tested unusual. I removed the soccer ball motor from the gear box. I still blew a fuse. All of my transistors on power driver board tested fine, along with the Bridge rectifier and capacitor.
I have found no one come up with a definitive fix for this. It seems everyone just unlplugs the motor for the soccer ball and plays.
i dont want to just throw parts at it with out a definitive reason. Although a new controller board and motor are not terribly expensive.
If anyone has any insight or perhaps something I have missed, assistance would be appreciated.
#2 6 years ago
I tried the board from the wcs in my tz.. no fuses blew.... does that really mean anything?
#3 6 years ago
I'm thinking about just replacing motor. Any thoughts?
#4 6 years ago
Although that's an odd failure for a motor, it's not unheard of and based on your troubleshooting that's where I would go first. My first guess would have been a gummed up gearbox, but you eliminated that. I would still clean and re-lube the gearbox while you've got everything apart.
#5 6 years ago
Quoted from terryb:
I think I am going to give that a try. It looks like the motor is sold with gearbox. I am really stumped on this one. I will report back once I get new motor installed.
#6 6 years ago
Sounds like the motor to me too...
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
2 months later
#7 5 years ago
Any News on this? I have the same problem
1 year later
#8 4 years ago
Quoted from thadawkins:
Yes, It was the motor.
1 year later
#9 2 years ago
Got the ole "Check F115, F116, J112 and opto 12V supply" message. Fuse F116 was blown. Replaced and went into test, soccer ball was acting weird. Unplugged soccer ball motor and replaced F116, this fixed the issue. Game can play with soccerball motor disconnected. Ordered new motor/gearbox. I will try to report back when motor is swapped.
4 months later
#10 2 years ago
Quoted from Neozone:
I'm in a similar boat. Did the new motor fix it for you?
$ 63.95
$ 26.95
Pinball Pimp
Playfield - Plastics
$ 11.95
KAHR.US Circuits
$ 49.99
$ 329.99
Lafayette, LA
$ 8.50
Pinball Invasion
$ 9.95
$ 219.00
Lit Frames
Professor Pinball
$ 259.99
$ 29.99
Pinball Shark
Pinhead mods
$ 41.99
Lee's Parts
Nezzy's Pinball Prints
4,300 (OBO)
Balt, MD
Plantsville, CT
$ 85.00
$ 17.50
This page was printed from https://pinside.com/pinball/forum/topic/wcs-fuse-116-soccer-ball-motor-board-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
