Changing the motor for the soccer ball on my wcs 94. Don't know how to seperate the old motor from the metal plate the ball spins on. Any help? Thank you.
The motor is attached to the transmission by those two largeish flat-head screws, one of which is visible in the image. If you're meaning that you need to remove the motor AND transmission, there should be screws on the back side of the metal mounting plate - you'll have to take off the ball and drop the whole assembly from the playfield.
Thank you for replying but I figured it out. I just couldn't get the metal plate off of the playfield. Then I saw the two allen screws in the side of the post and felt like an idiot. Changed the motor out, soldered it, put everything back together and it works better than it did before!
This page was printed from https://pinside.com/pinball/forum/topic/wcs-94-soccer-ball-motor and we tried optimising it for printing. Some page elements may have been deliberately hidden.
