(Topic ID: 279172)
Waxing pins makes them play waaaaay too fast...what to do?
By DakotaMike
2 years ago
  • 25 posts
  • 16 Pinsiders participating
  • Latest reply 2 years ago by chuckwurt
    #1 2 years ago
    Hey all, title is pretty self-explanatory. I've noticed that after I wax my newer pins with carnauba wax , they play way too fast. Like so crazy fast that it's not fun, and plastics are at risk of getting broken, ect. Is there any way to overcome that?
    My old 1980 Black Knight was great with wax, but my new Sterns are awful with it. Even some of my B/W games like Johnny Mnenomic or Mousin' Around are scary fast with wax. I've literally chipped plastics on those games after waxing, to the point where I had to clean the wax off. I left it on some high-wear areas like shooter-lane exits and top rollovers, but that's it.
    The only reason I want to wax is to protect the pf, but I don't want to damage plastics and mechs because of the post-wax speed boost, and I don't want the games to play like crap. Is there anything I can do about it?
    Right now, I'm operating under the precept that the pf clears on newer Sterns are robust enough that it's not worth the downsides of waxing. As long as I clean the pf regularly, and make sure the balls are in good shape, should I be fine on my newer games? Looking for some advice. At home I don't put enough games on my pins to really worry about it, but I might be doing a little routing soon, so it's of slightly more concern to me now. But again, I'd suspect rough/scratched pinballs are the main cause of pf damage, as well as a lack of mylar over high-wear areas such as ball-drops. What does everyone else think?
    #2 2 years ago
    Quoted from DakotaMike:
    You are right that modern games don't really NEED to be waxed the way older ones did. As long as you keep it clean with healthy balls, you should be fine in a home environment. Wax will give a bit more protection, but I'm pretty sure it mostly just helps keep them clean longer. If you do wax (which is best), the crazy fast play will stop after a couple dozen games though, and it will be back to normal.
    #3 2 years ago
    Quoted from Jediturtle:
    I've often wondered though, once those initial games are done and the ball speed slows back down, is there even any wax left on the pf? I would think the ball speed slows because the wax has been worn away; otherwise, what's happening during the break-in period?
    Plus, I'd even speculate that owners that wax their pins regularly do more routine cleaning, and more frequent pinball-condition inspections, than other owners; and that could correlate to less pf wear regardless of the presence of wax or not.
    #4 2 years ago
    The wax doesn’t last and neither does the speed.
    Personally I think waxing is a waste of time.
    #6 2 years ago
    Don't push the flipper buttons so hard.
    #7 2 years ago
    Don’t wax on a new game except after a really long time and sparingly. But really, novus 2 when it’s dirty and that’s really it.
    Older games I will wax a couple times a year. Helps bring the shine back to those old playfields and speeds em up.
    #8 2 years ago
    Quoted from chuckwurt:
    Novus 2 is even overkill in most cases. Unless you have dirt really ground in or nasty ball trails, Novus 1 should be plenty. Never use anything more aggressive than necessary. If #1 doesn't do the trick, then bust out the #2.
    #9 2 years ago
    I wait for ball trails. Novus 2 because I know it will work, then done
    #10 2 years ago
    No such thing as too fast.
    #11 2 years ago
    Quoted from beelzeboob:
    How about waxing STH, hitting the drops, they brick, and the ball flies OVER the flippers to the drain? That’s when I’m like, okay no wax.
    #12 2 years ago
    Oh shit. Is THAT why that happens???
    #13 2 years ago
    Oh! That’s what happened to my STH! I always wax a new game. WHIZZZ WHAMMM BANG WHISHHHHHH BLAM
    #14 2 years ago
    I'm generally not bothered with it, but I find with Maiden, that after waxing, the ball no longer auto-plunges into the loop, and it takes a long time to go back to normal (doesn't load multiball, and some rejects can lead to a drain).
    #15 2 years ago
    Just cleaned my IM pro with Novus 2 for the first time and replaced the balls. Bloody hell I see what you mean, the balls are flying.
    2 months later
    #16 2 years ago
    what kind of carnauba wax did you use , DakotaMike?
    #17 2 years ago
    I like to clean and wax often. When cleaning I check for loose post, screws and other playfield parts. I usually find something loose while doing this. I like the fast play after waxing. I hope that I am protecting the playfield by doing this. I want my machines to last forever for me and the next owner.
    #18 2 years ago
    Quoted from Matthew2015:
    Uh, I think the P21 carnuba stuff.
    #19 2 years ago
    If you want a carnauba wax, Mothers Step 3 Pure Brazilian liquid is equal to any and readily available in automotive stores and reasonably priced.
    #20 2 years ago
    Quoted from Bamaro:
    If you want a carnauba wax, Mothers Step 3 Pure Brazilian liquid is equal to any and readily available in automotive stores and reasonably priced.[quoted image]
    Don’t use the liquid, they contain petroleum distillates. Use the paste in a tin
    #21 2 years ago
    Quoted from PinRob:
    Oh yeah, when I do wax, that's the type of stuff I use. Gotta swirl that rag around the tin until the wax softens enough. Yep, yep.
    #22 2 years ago
    Quoted from PinRob:
    What petroleum distillate are you concerned about. The ingredients in the liquid and paste are identical. Just some small differences in amounts to account for the thickness.
    #23 2 years ago
    Drink more coffee...
    #24 2 years ago
    Don’t wax
    1 month later
    #25 2 years ago
    Quoted from Bamaro:
    It’s liquid. Don’t put liquid on a wooden playfield.
    This page was printed from https://pinside.com/pinball/forum/topic/waxing-pins-makes-them-play-waaaaay-too-fastwhat-to-do and we tried optimising it for printing. Some page elements may have been deliberately hidden.
