(Topic ID: 266865)
Water softener repair
By woody24
  • 8 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by woody24
    #1 4 years ago
    Ive been trying to fix my old water softener. I'd rather fix it than replace it right now. It's been giving me an E-1 code before. I've replaced the switch and seemed to work for a few weeks. Then today it gave me another E-1 error. I jimmed some wires around and it started working again. But then during the regen cycle, it gave me an E-3. All have to do with electronics.
    I was planning on replacing the capacitors, but I don't have 1 to 1 replacements. Do any of these from the kit I have work with the ones installed?
    Anyone have any suggestions on what else to try? Anything else on the board need looking at? I did look for cold solder joints, but do not see any.
    The water softener is a Kenmore 625.3483500. Link to the manual if anyone would care to check out: https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0807198.pdf
    20200420_181821 (resized).jpg20200420_181821 (resized).jpg20200420_182146 (resized).jpg20200420_182146 (resized).jpg20200420_182205 (resized).jpg20200420_182205 (resized).jpg20200420_182230 (resized).jpg20200420_182230 (resized).jpg
    #2 4 years ago
    Definitely going to follow this thread as I'm having some issues with mine. Looks like a supercap in there?
    My issues are with the recharge however my tank is over 15 years old so I have different problems than you likely do.
    #3 4 years ago
    Quoted from EJS:
    Just updated. Mines about 20-25 years I think. But it's actually been disconnected ever since I got the house 10 years ago. Just recently decided to use it, as I need to stop all the hard water issues.
    #4 4 years ago
    I've noticed that when it loses power, it reset all the settings, which does make me believe that it is the capacitors as theirs no button battery on it. Manual said it should be able to hold settings for up to 6 hours.
    #5 4 years ago
    Quoted from woody24:
    That problem is going to be related to your super cap and not related to your other "error" issue. How long have you had the thing plugged in recently? On the equipment I work on for a living we have super caps. Sometimes being powered on for some time can regenerate those caps but with age there isn't much you can do about that. This type of cap won't be found in your stash. The super cap is kind of like a battery except more short term.....like up to 6 hours
    #6 4 years ago
    Quoted from EJS:
    It's been plugged in for probably 2 months at this point. Power flashed off for a second last week and lost the settings.
    Guessing the other cap has dried up, and is what's giving me errors?
    #7 4 years ago
    I wouldn't bet all my money on that other cap just yet....
    You said you shake on the wires and it acts up. Have you looked at the components on where those wires end up?
    Is there another PCB in there that is the LCD display or is that the board we are currently looking at?
    When you command a recharge you can force it to recharge immediately (vs usual scheduled time). Once it starts recharging you might be able to force the system into it's next phase by hitting the recharge button again. This will step the rotor into the next phase. You can keep stepping it until it basically completes a cycle in 30 seconds whereas normally it would complete in a couple hours. Doing this a few times may dislodge any buildup you might have causing some errors.
    As a rule of thumb, most softeners have breakdowns due to mechanical failures before anything else.
    #8 4 years ago
    So after playing with it more last night, I think I've figured out it's the motor. All I did one time was tap the top of it with a screwdriver, and it started again. I went ahead and ordered a new one. Wasn't thrilled about paying $60 for one, but I'd rather pay that than $400+ for a new one right now, if that's all the issue is.
    And while I was at it, I went ahead and ordered new caps for it. Hopefully solve that saving data issue at least.
    Was also kinda curious what your issue is. I've had multiple issues with mine, and every time, I think that's the last one. The first issue was the Venturi valve. I took it apart, and found the grommet was completely disintegrated and one part completely missing. Bought a replacement, and it finally started doing to the brine wash. Before the tank would just fill with water, but never actually do a rense.
    Also learned that there are a few things that you can do to clean the resin. Guess over time it can get coated with iron and other things that the brine wash cannot fully wash away.
    This page was printed from https://pinside.com/pinball/forum/topic/water-softener-repair and we tried optimising it for printing. Some page elements may have been deliberately hidden.
