Is it possible to repair a planked area by putting a waterslide decal over it, without sanding it down first? Or will the small cracks be noticable through the decal?
Also, I read Vid´s guide but can´t figure out if the water slide decal can be clear coated first, before applying to playfield? Or will the clear coat vanish once the decal is put in water?
I will not clear coat the entire playfield, so I prefer if there is a way to clear coat the decal before if applies on the playfield?
I bought decals for laser printer and an acrylic clear coat spray can (not 2 component).
