(Topic ID: 232436)
Water Slide Decal - What kind of adhesive to apply on insert?
By Barakawins1
3 months ago
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 3 months ago by nicknack66
    #1 3 months ago
    I'm looking to use a water slide decal on an insert. There is no glue on the back of the water slide paper. What adhesive can be used to adhere it to a plastic
    insert? Anyone do this?
    #2 3 months ago
    Quoted from Barakawins1:
    3M 467MP is my go-to. Comes in a roll. You cut what you need and then stick it to the decal, then remove the 467MP backing and you have a decal with adhesive on it that you can stick to something. Also works great to make replacement drop target stickers from scratch like this:
    http://www.theteardown.com/gallery/categories.php?cat_id=19
    You'll use it a lot once you know what it can do.
    #3 3 months ago
    I replaced a Jokerz center ramp and elevator plastic. I was unable to source the artwork. I removed those pieces and cleaned off the old adhesive. Attached them to the new plastic using 3M 467MP. I think I got it from pinball restore. It worked great.
    #4 3 months ago
    I guess this is the stuff. Going to order today. Thanks guys!
    #5 3 months ago
    If it's truly a water slide... It should have water soluble adhesive already on it. Put it in water slide it off the paper. Use micro sol/set before and after to boost adhesion.
    #6 3 months ago
    Yes, setzkor is correct: a waterslide decal does not need adhesive. The adhesive is already there and is activated by water.
    So check if your waterslide decals are in fact waterslide decals first.
    #7 3 months ago
    What is micro sol/set?
    #8 3 months ago
    Micro sol is essentially a primer for the surface. Put it on the insert and surrounding area before the decal. Micro set you can put down after to help set further to the surface... Not completely necessary. The sol step I consider necessary for sure. There will be a noticeable difference here. You wshould no longer be able to peel the decal if you do this one.
    amazon.com link »
    Also if it is a water slide you will likely need to clear the decal or mylar it to avoid wear.
    #9 3 months ago
    Does the micro sol impact any of the remaining original art on the insert? I have a few inserts where the art work is worn but not totally gone, and by putting a water slide decal over the worn insert it it makes it look a lot better. I was just planning on covering the decal with mylar to protect it and help with the adhesive, but in reading this post was thinking maybe I should first use micro sol when applying the decal. However, I don't want to do that if it will impact the existing insert art.
    Yorktown Parts and Equip
    £ 29.00
    PinballToys
    $ 999.00
    $ 22.00
    Operation Pinball
    $ 159.99
    $ 9.99
    $ 159.99
    $ 69.99
    $ 35.95
    MicksPinball
    $ 7,499.00
    Gulf Coast Pinball, LLC
    $ 159.99
    $ 86.95
    $ 68.00
    PinWorlds
    $ 48.00
    $ 0.35
    Gameroom Mods
    Playfield - Plastics
    Bright Lights Pinball
    $ 18.95
    $ 24.95
    The MOD Couple
