Literally...
So I have two broke TFTC's....The one I traded with Devil and another one I'm fixing for a friend. Both have board issues. The second one I had identified as a bad PIA on the switch matrix. Ordered a new 6821 and buffer chip and sockets. I have a friend that does solder work for a living in building power supplies for cell phone industry. I'm an ok solderer, but this PIA had been replaced once before (no socket) and had a couple of trace jumpers so he offered to come over and repair it.
Well, he wanted to show me a trick I'd never heard of...Using a heat gun to soften all the solder points on a 40 pin IC at once. He did use wick to remove most of the solder at each point. Then using the heat gun (600 deg and 1000 deg setting on mine) at 600 deg, heated the IC a few seconds and out it popped. Cool! The 20 pin buffer chip (much smaller) is right beside it so he decides to do this one too...only this time he inadvertently put it on 1000 deg! within seconds the board starts smoking and all the traces where the 40 pin PIA was go up in smoke as the board bubbles.
So, in the wink of an eye, I see my $250 board go up in smoke. He felt bad, I felt sick, but I let on no big deal....Didn't want to make him feel worse. He thinks he can take it to his 'shop' and fix all the traces, but I don't think so....
Anyone have a nice used one they want to sell? Sending the other one off to Clive...not taking anymore chances.
