Restoring a TAF and it’s the first time I took a game apart when I feel like I know what I am doing as opposed to when I shopped it the first time 10+ years ago. Two things
1) Is there normally supposed to be small thin washers between the tops of the posts between the post and the plastics. Some had them and others did not.
2) is there supposed to be washers between the top of playfield and the posts that get bolted from underneath . I know there is always a washer between the nylon nut and the bottom side of the playfield. Same question goes for the bolts on the ball guides that bolt on under the playfield.
