Following the theme of this post https://pinside.com/pinball/forum/topic/warning-to-rottendog-327-owners-check-it-now by goingincirclez
I just spent the better part of last night troubleshooting an issue with a coil locking on right after power up. After several hours of investigation,1 burned drop target coil, and replacing Q26 multiple times, I found out that the short was caused by this trace on the back of the board.
The problem is that the solder mask does not cover the trace right by the ground pad around the screw mount by Connector J122 on the bottom of the board. When the board is screwed into the game, the metal standoff will short this trace to ground, which will lock the coil on. On top of that, there was a solder build up on that trace which contributed to the likelihood of it shorting out when screwed down.
This only affects Pin 1 on J122, J123, and J124 of the board, and in the case of Dracula, this happens to be the Drop Target coil.
I fixed this by removing the solder blob on the trace, and then applying super glue gel over the exposed trace, but other options could include cutting the trace and using a jumper wire, or using an insulating washer between this pad and the screw mount.
Hopefully, this post will save some of you a lot of time + spare a few coils from a melt down!
