A local collector was kind enough to part with a Williams Police Force. It had been stored in their warehouse for 15 years, and probably in another warehouse before that as they bought it in a 'bulk sale'. It's in pretty rough shape, but mostly complete. This is my first pin, and first pin project. I want to learn the hard way
Main issues: Playfield paint missing, bottom of main display and jackpot displays are out (there are white specks on them - outgassed?), spinner assembly missing, car not working, diverter error, main ramp in bad shape, interconnect board damage, CPU board damage
Plans: Address all main issues, custom LED's, NVRAM.. this won't be a "level 3" restore, but I want it to look good enough, and be fully functional.
I'm anticipating the most difficult parts of this restore will be the playfield paint, board work, and finding or machining a replacement spinner. I have not played the game yet because of the condition of the playfield. There is a layer of dirt on it, it has broken plastic laying around, and lots of areas where the paint is missing. It appears that the Mylar was previously removed. I know it will be a ton of work, but I'd prefer to restore the playfield myself, and 2PAC it. I'm in central Illinois, so I probably won't be able to work on the paint for several months due to the cold weather. I'm going to take everything off the top to see exactly what parts I'll need (lot's of missing hardware and some plastics), clean with Naphtha, wax, and reassemble so I can get everything else working.
The backbox key was broken off inside the lock, so I had to bend the plexi (did this originally come with glass?) to get it out. Somehow, I found the extra key on top of the playfield glass. I removed the broken key with two knives, fixed the lock mechanism as it was not connected, and made a copy of the key.
I'm a little hung up on order of operations. Should I work on the boards next? Where should I start?
Here are a few pictures showing the current condition. What do you think? Have you seen a playfield that was in worse shape restored with an airbrush and waterslides?
IMG-2550 (resized).jpgIMG-2557 (resized).jpgIMG-2607 (resized).jpgIMG-2623 (resized).jpgIMG-2708 (resized).jpgIMG-2720 (resized).jpgIMG-2722 (resized).jpg
