Found this thread searching Google for Sorcerer pics.
I'm rebuilding a set of boards from parts for a customer's sorcerer.
Does anyone have a good pic of an original power supply?
I just want to make sure the PS should have the relay. Some schematics I looked at had the relay jumpered over with a diode installed.
CPU board has been converted to a single 27c128 CPU ROM at U20, replacing the 2732 at U19 and the 2764 at U20. I also recapped both the CPU and speech board, repaired some damage and missing parts on the speech board, repaired 2 fried transistors in the special solenoid section, and did a little work in the display section of the CPU board so now the displays work and look properly.
Thankfully, there was zero corrosion on this CPU. It got an anyPin NVRAM to make sure it stays that way
PS (can't see, it's under the top deck of the test fixture) got a HV rebuild, fresh cap kit, and all connectors replaced, as they were pretty bad.
A nice reason to give my new to me factory Sys 9 / 11 test fixture to check out some boards
