Just putting my feelers out for one of these as I may need one. Does anyone have one that's not been hacked?
Rudi
Rudi
Quoted from RudeDogg1:That's a good price do they not come with the metal sides then on the ready built ones?
You can re-use your old ones.
To have these made is simply not cost effective and they don't wear out.
Ok no probs I only asked because they are riveted which is something I don't own but then I could bolt them instead. Once I've I'm sure this one is dead I may well put in an order
Quoted from RudeDogg1:Ok no probs I only asked because they are riveted which is something I don't own but then I could bolt them instead. Once I've I'm sure this one is dead I may well put in an order
Yes, drill out the rivets and use 3mm nuts & bolts. If you end up buying a board remind me and I will include the correct nuts & bolts. Only about 1/4 of buyers use a bracket as many machines don't use them - the board clips into plastic standoffs in most machines.
This page was printed from https://pinside.com/pinball/forum/topic/wanted-bally-williams-opto-sw10-pcba-18159 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
