I always considered Ironman's soundtrack to be one of its strong points, great music, callouts and action sounds. Buuutttt, the stock setup leaves some to be desired due to budgets at stern. Anyways I wanted to upgrade the sound output but didn't want to spend a whole bunch, heres how to get great results for ~$20 (all from parts express)
First the woofer, pins don't have the best amps, so an efficient woofer is a must this 8" is sensitivity is 95db, and goes down to 45hz. I tried a few woofers and this thing ROCKS! (and is only $18):
Ok so your thinking usually it should have a low pass filter, however since modern sterns have a capacitor for a high pass in the backbox the sound does sound fairly balanced. Which brings me to our next point, the high pass filter.
Ok so the back box speakers on my VE are decent, I tried a few 4"ers in my iron man and surprisingly the oem sounded the best. A little loose on the bottom end but the high frequency was the clearest. However, they do employ a 22uf cap for a high pass filter, as you can imagine this cap is garbage. So a simple swap to a better 22uf NP electrolytic and a 0.1uf MKP for a bypass sounds better. Here are the parts: (about $2 for the pair)
http://www.parts-express.com/22uf-100v-electrolytic-non-polarized-crossover-capacitor--027-348
http://www.parts-express.com/audyn-cap-q4-01uf-400v-mkp-metalized-polypropylene-foil-crossover-capacitor--027-101
Try it out and let me know what you think, I love mine now! Should work on other sterns as well. Enjoy!
