(Topic ID: 229941)
Wall/Scoop Issue
By twitami
5 years ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by twitami
    #1 5 years ago
    My walls and scoops arw suddenly not working correctly. a few of the walls wont go up, and the lights in 4 of the scoops are off. I teated in diagnostics. The game has less than 100 plays and hasnt been moved. Few pics included. Any ideas?
    57F78A53-BE82-4974-AA4C-DD3D33DF0952 (resized).jpeg57F78A53-BE82-4974-AA4C-DD3D33DF0952 (resized).jpeg8079B099-088F-498B-B9AE-01B67BAB06E9 (resized).jpeg8079B099-088F-498B-B9AE-01B67BAB06E9 (resized).jpeg91226CDE-1684-47D6-909F-CF65766F3432 (resized).jpeg91226CDE-1684-47D6-909F-CF65766F3432 (resized).jpeg93F0F90B-2622-4554-B6DB-7F0277EF2E0B (resized).jpeg93F0F90B-2622-4554-B6DB-7F0277EF2E0B (resized).jpegBFDBA2DF-3980-4E7E-A5CD-2A4BF3720CEC (resized).jpegBFDBA2DF-3980-4E7E-A5CD-2A4BF3720CEC (resized).jpegEA11747A-3C84-4056-B7DC-E22292B485E5 (resized).jpegEA11747A-3C84-4056-B7DC-E22292B485E5 (resized).jpegF07A3840-19EF-498E-AD16-9576DF1F7756 (resized).jpegF07A3840-19EF-498E-AD16-9576DF1F7756 (resized).jpeg
    #2 5 years ago
    Well, dug in a little bit. Nothing obv thats loose that I can see. Not sure where to go from here.
    First three walls dont go up, and right four scoops arent lighting up, but they go up and down.
    195B9657-393B-4C1C-823B-0C773D8EC700 (resized).jpeg195B9657-393B-4C1C-823B-0C773D8EC700 (resized).jpeg
    #3 5 years ago
    Hi Twitami,
    Remove the balls and then take out the ball trough - should only be a few screws to do that. From there you will be able to see the coils and the boards that control the coils and lighting for those scoops. Check any small ribbon connectors that connect to the board and make sure they are plugged all the way in. Check the fuses too. For any of the front walls/lights that aren't working check the boards on the front side that drive the wall coils/lights - again for any loose connections/fuses. They are the ones directly under the walls / coils. You can see them easily - just look through the coin door and they are right in front of you.
    #4 5 years ago
    Ok, thanks everyone. Got the lights in the scoops working again, was a loose connection it seems. The 3 walls not going up were a fuse, but upon replacing it as soon as Warehouse mode was active in the game, they stopped working again. Ordered some more fuses to try again just to be sure.
    #5 5 years ago
    Great to see you've fixed it almost. For the fuses make sure they are 4A Slow Blow fuses. There should be a label in the bottom front of the cabinet that tells you the fuse type needed for all the different pcbs.
    #6 5 years ago
    I got the right fuse, but only had one. Ordered a bumch so I can try again. We will see what happens. Cant see anything obvious.
    This page was printed from https://pinside.com/pinball/forum/topic/wall-scoop-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
