Mine on location does this. The head of the post looks like a Hershey's kiss as it was loose and spinning around and the ring has worn a notch out of it. Appears to be a common issue as I have seen it on another on location.
All three of my WD have this issue. Plus my WD LE had the bicycle girl ramp issue.
I just don't understand how these EXTREMELY obvious flaws/defects/issues get ignored during game development. Do they not actually play the machines they produce???
Quoted from ExtremePinball:All three of my WD have this issue. Plus my WD LE had the bicycle girl ramp issue.
It affects absolutely nothing so I don't think it's a big deal, you are kinda overdramatic aren't you?
Quoted from Rickwh:Can you just grind the ring down a bit? What about removing the post? Or shortening the post?
Yep I used a dremel on mine. Eventually it will just wear down naturally from hitting it tho.
Quoted from centerflank:It affects absolutely nothing so I don't think it's a big deal, you are kinda overdramatic aren't you?
No, I'm not.
The ball launching off of the ramp on WDLE does indeed "affect" game play. Metal shavings on a playfield also does indeed have an "affect".
Edited as too harsh.
Quoted from ExtremePinball:No, I'm not. What YOU think, isn't worth the electrons used in conveying the thought. And a complete lack of standards on your part, does not equate to being "overdramatic" on my part.
I'm a guy that spent over $150,000 in the last year or so on pinball machines. I buy 2-3 of every Stern & JJP pinball currently manufactured.
The ball launching off of the ramp on WDLE does indeed "affect" game play. Metal shavings on a playfield also does indeed have an "affect". Therefore, you are simply wrong.
I've read some of your posts and it appears that you enjoy getting into pissing contests with any available poster. Good luck with that.
So, I'm just meaning to help you here:
Don't let things like this get you that upset that quickly. No one cares what kind of $$ you spend on machines. That is irrelevant.
You're new here; I get that, hence why I am saying it: don't wear your feelings on your shoulder here. People for the most part mean no harm on Pinside. Sometimes, people type what they lack the courage to say to your face. Centerflank is not one of those guys, and he's not trying to pick a fight with you. You're being "trollolololol'd" or in this case, my avatar (troller coaster).
I agree with you: it does have an effect. Metal dust is not good for the clearcoat and could potentially reek havoc on a game. Simplest thing to do is get a simple tiny rubber and double them up on the post. Did this on my TWD Pro and Prem and documented it on the owner's thread:
https://pinside.com/pinball/forum/topic/twd-club-only-walkers-not-welcome?tq&tu=npo#post-2900573
So, to summarize:
1. Chill and go with the flow on Pinside.
2. Yes, it does affect the game. Place a 2nd rubber on the post, and all should be good (until that rubber starts to fall apart and spew rubber shards on the pop bumper body).
So you are saying you aren't overly dramatic?
Quoted from centerflank:So you are saying you aren't overly dramatic?
Not anymore. I do apologize. I hope you accept.
To better convey my thoughts.... Within the first 2 games of WDLE, the bicycle girl ramp problem was clearly evident. Much like the current GOTLE left orbit defect, noticeable on the first game out of the box. Both obviously affect game play to a severe degree. I would think that the professionals would play the machine they built before going into full production. At the very least, play it after production and correct problems then. But obviously, neither of those things happened, as evidenced above. While lame code is expected as it is a simple fix, issues like these are preventable. Thanks for understanding.
Quoted from ExtremePinball:Not anymore. I do apologize. I hope you accept.
Yes, I agree, BG ramp needed a fix fast, people had the bottom of the rivets wear through the Mylar under the ramp flap so that really blew.
My newest TWD had the fix kit installed already so they do adjust things on the fly
Yes, i just noticed this issue on mine last week as well as the center divider in the skill shot lanes was loose. I'm guessing repeated bashing of the ball from the pops into the divider loosened it.
This page was printed from https://pinside.com/pinball/forum/topic/walking-dead-pop-bumper-ring-is-hitting-stand-up-post and we tried optimising it for printing. Some page elements may have been deliberately hidden.
