Quoted from Shenanigander:Great to know I don't have to spend the four or $500 on the pinball browser as well.
For what it's worth, Pinball Browser is a $20 donation.
Quoted from Shenanigander:I don't have to spend the four or $500 on the pinball browser...
Where did you get those numbers? Pinball Browser asks for a $20 donation. If you're being asked for $400-$500 you're getting a pirated version put out by a scammer and oga83 (the developer) probably isn't getting anything.
Details and download link here: https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images#post-872012
Quoted from Hashman:So my favorite TWDLE mix has always been kpg's mix of @skb's sound rom for 1.56. It had the best mix of redneck, show sounds and music for me.
I have missed it so much since 1.60 so I was wondering if someone would be willing to convert it to 1.60 for the LE? Most happy to paypal donate for the trouble. Anyone able to help?
Quoted from jorge5240:More
This!!! I haven’t updated because I didn’t want to lose his mix. The other ones don’t have the right mix for me. I would be willing to donate as well.
Hey guys. I uploaded my own cleland 1.60 / kpg 1.56 mix 5 months ago to dropbox. I posted it up above on post #1073.
Junky
Quoted from Riffbear:Hi guys I just bought TWD premium - updated the code to 1.60 (stern file) how do I get this sound pack on?
Which file do I need to download?
Thanks in advance!
If you want mine, (Cleland soundbites with Nine Inch Nails and Radiohead music, no lyrics) then pls private message me. Some others are available in the thread via links I think. Lots of good options.
-KG
ATLpb.com
Quoted from YeOldPinPlayer:Where did you get those numbers? Pinball Browser asks for a $20 donation. If you're being asked for $400-$500 you're getting a pirated version put out by a scammer and oga83 (the developer) probably isn't getting anything.
I forget what it is called but it is a system you can buy so that you can completely change the audio of your game. My friend has a couple. They were $399 or $299usd each.
Quoted from Shenanigander:I forget what it is called but it is a system you can buy so that you can completely change the audio of your game. My friend has a couple. They were $399 or $299usd each.
That's PinSound. It's $399 because it's a physical replacement soundcard (well worth it). That's for older systems, this is all done in the game code with software.
Quoted from cabuford:That's PinSound. It's $399 because it's a physical replacement soundcard (well worth it). That's for older systems, this is all done in the game code with software.
Yep that is it!
That has nothing to do with #walkingdead or Pinball Browser.
Pinsound is a fine product. The games it works with are listed here: https://www.pinsound.org/pinballs/
Quoted from Eskaybee:Here's a modified cleland sound package. 30% show sounds / 70% factory scripted.
v1.56 LE/Prem Only
https://www.dropbox.com/s/8bjh1m3eis1e2pf/TWD156LE_SKB.BIN?dl=0
I have been slacking and finally updated to 1.6. What would be the closest sound package to above? This one was perfect for me.
Thanks,
Mike
Quoted from jorge5240:I have been slacking and finally updated to 1.6. What would be the closest sound package to above? This one was perfect for me.
Thanks,
Mike
Bump for some love
Quoted from imagamejunky:Hey guys. I uploaded my own cleland 1.60 / kpg 1.56 mix 5 months ago to dropbox. I posted it up above on post #1073.
Junky
Oh man I just finally got around to installing your mix! Thank you! Dead set favorite mix for 1.60! Thank you!
Quoted from Hashman:Oh man I just finally got around to installing your mix! Thank you! Dead set favorite mix for 1.60! Thank you!
You're welcome. Glad you like it
Could somebody post a video that shows off the coolness of these audio modifications. I would love to get a taste before I go ahead and install one into my Walking Dead.
Quoted from Shenanigander:Like some game play action with the audio cranked for example
https://pinside.com/pinball/forum/topic/twd-nine-inch-nails-radiohead-mix-by-randomkg#post-3248716
Wow that is amazing! I must install something asap! I see there is about 10,000 different options out there so I may need some advice.
I have a TWD pro. The radiohead/NIN sounds amazing but I might be interested in the Tool version. I guess I could try several and then choose from there. I love the options with the custom/additional call outs. I would be up for trying an R rated version. All in all what would you guys say are the best 3 options out there and I will maybe try them all and pick from there! Thanks for your help!
Original Cleland version R rated
Quoted from Shenanigander:Wow that is amazing! I must install something asap! I see there is about 10,000 different options out there so I may need some advice.
100% least case scenario replace the hillbilly with Cleland. If you want mine PM me. If you want others I believe they are available in the thread. They all improve upon a great machine.
Quoted from ATLpb:100% least case scenario replace the hillbilly with Cleland. If you want mine PM me. If you want others I believe they are available in the thread. They all improve upon a great machine.
Best mod ever.
Hi - I have a clubby version on the one I just bought. Did that get updated to 1.60? Sorry don't know the name of it but basically like cleland but it's a much bassier version....
Bump on this - it's actually called KPG.
Can someone repost 1.56 KPG Prem/LE version? I want to leverage it for some 1.60 goodness.
KPG member non responsive thus far and all links broken.
I actually have it on my machine but don't believe I can extract it from the machine right?
Quoted from imagamejunky:Check my posts earlier. 1073
Hope this helps
Thanks. I'm attempting to recreate kpg for 1.60. can't run the r rated version either.
If someone can repost kpg 1.56 that would be ideal
Added over 4 years ago:Got it
does anyone know the callout/spot script ref for the outlane sound effects? I'm trying to incorporate the whistle as the effect.
Sorry for delays, I take breaks from pinside sometimes. Yes it’s possible...
All NIN/RH requests replied to!
I think someone needs to make an all Cannibal Corpse version. That little taste at the end sequence in the Slayer version is such a tease, I will donate heavily for such code.
Quoted from Hazoff:I think someone needs to make an all Cannibal Corpse version. That little taste at the end sequence in the Slayer version is such a tease, I will donate heavily for such code.
who would be sick enough to do that?
Quoted from ezeltmann:who would be sick enough to do that?
I was hoping u Come on man lets get sick
Feel free to use only this album.
Hope this helps
Is there a pro version of this code?
Quoted from Sparky:Is there a pro version of this code?
I never made a pro version. Give me a little time and I’ll make one for you.
Junky
Quoted from imagamejunky:I never made a pro version. Give me a little time and I’ll make one for you.
Junky
No problem. Looking forward to it!
As requested by Sparky....
This is my mix of Cleland's 160R and KPG's 156 for TWD PRO.
https://www.dropbox.com/s/8ub918niv7v27q0/imagamejunky%20TWD-PRO-Cleland-160R-KPG-156%20mix.BIN?dl=0
Hope you like it.
Junky
Link is gone
Quoted from colonel_caverne:Hi,
I’m not familiar with TWD show in VO, so any version is fine for me.
However, can someone tell me which one is the best to hear the jackpots callout?
No one can advise me?
I'll play mine later and comment. From memory I don't believe any versions play a "jackpot" callout. They just play sounds
Quoted from imagamejunky:As requested by Sparky....
Hope you like it.
JunkyAdded 8 days ago: Link is gone
I'm picking up a TWD Pro tomorrow. Any chance of getting a re-upload?
I found this still worked
https://pinside.com/pinball/forum/topic/the-walking-dead-code-update-160/page/4#post-4107914
