(Topic ID: 117960)
Walking Dead LE Sound Replacement v. 0.9
By milhouse
  • 1,141 posts
  • 229 Pinsiders participating
  • Latest reply 8 months ago by imagamejunky
  • Topic is favorited by 169 Pinsiders
There have been 32 images uploaded to this topic. (View topic image gallery).
25 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 1141 posts in this topic. You are on page 20 of 23.
#951 2 years ago
I was playing with the NIN version and was not in any mode at the start of the game (playing poorly) after maybe a minute the basic music stopped all together. Like it had reached a minute (or whatever) and didn't loop back.
#952 2 years ago
Quoted from ATLpb:
It's your speakers or some wire connection. I've never seen a Cleland version with distortion.
Thanks. I've been in touch with the manufacturer and am trying to work out the issues.
#953 2 years ago
Quoted from rai:
Yeah, I think that's a bug. I've run into that one a few times. It's an embarrassing reminder that I'm playing like crap.
#954 2 years ago
Quoted from 30FathomDave:
Guys I'm honestly confused by this. I will test when I get home in a few days. I seem to remember looping this my main game music perfectly...
#955 2 years ago
Walking Grateful Dead Pro and Premium are now online. Thank you Dr Joe for testing out the Prem/LE.
Download for Pro Version:
https://www.dropbox.com/s/3zlm4zaohrq5bgj/TWD156_GDEAD_CLELAND.BIN?dl=0
Download for Premium/LE version:
https://www.dropbox.com/s/laiulz91t9g334t/TWD156LE_GDEAD_CLELAND_7R.BIN?dl=0
#956 2 years ago
Hey guys I'm new to pinside and have a question. I just picked up a TWD Pro, it all ready has the voice mod in it. I would like to upgrade it with the R version. Is the dropbox file ready to install on my machine or do I have to mess with it?
#957 2 years ago
Quoted from Aguia71:
Ready to install.
#958 2 years ago
Quoted from Maken:
Ready to install.
Thanks Maken
1 month later
#959 2 years ago
can someone post the latest cleland R version for pro? The link is broken. I believe there is radiohead playing when you hit the woodbury shot. thanks
EDIT - found here:
https://pinside.com/pinball/forum/topic/where-is-the-most-recent-cleland-twd-code
#960 2 years ago
Does anyone know what sound in the code plays when woodbury shot is reached? I thought cleland's mix had the radiohead in it for this shot but it just must be premium/le not pro. I want to change it out myself and I already have pinbrowser. Thanks.
#961 2 years ago
Woodbury is 0x3B. Check out my Grateful Walking Dead thread for a fairly complete list.
#962 2 years ago
How do you change the code and not lose the high scores? I know I did it before when I changed songs on Mustang a couple years back but I can't remember how to do it. I'd love to try out all the different ones but I hate to lose my high scores.
#963 2 years ago
Quoted from BillySastard:
You don't without additional hardware.
#964 2 years ago
I noticed a phrase or two on the R rated 1.56 version on my premium I am running doesn't sound nearly as loud
as most of the other phrases.....
The Negan phrase "not making a decision is a BIG decision" doesn't seem to play nearly as loud
and gets lost with other sounds most of the time when it plays.
I remember I adjusted a sound attenutation setting in the software a while back to make the voice callouts
louder, but for some reason this particular phrase seemed to lessen in volume now.
Anyone else experience that?
John
#965 2 years ago
Quoted from Rondogg:
awesome thanks!
#966 2 years ago
Quoted from johnjones:
John
No that quote is very loud on mine. When you did the sound attenuation(not treble and bass settings) you did go into the negative numbers right? If you go into the positive numbers it actually makes it quieter.
#967 2 years ago
Write your high scores down, then use Pinball browser with any code you want to use. Under the "High Scores" tab update the default scores to yours, save and your done. I just did that with the latest Star trek code that includes music from the movie.
#968 2 years ago
Quoted from earetz:
Wow. I saw that screen in PB and I though "Nah, couldn't be that easy"!
#969 2 years ago
Quoted from Phbooms:
Yep, I put in a negative number. Most of the other voicecalls are much louder and have no issues. For some reason it is mainly that one quote....wierd.
Maybe I will play with the sound settings some more or try re-loading the software to see if that helps.
#970 2 years ago
Hey guys I am having a really tough time installing code in my walking dead LE. I have tried 4 different usb drives, all formatted to fat32 and nothing in root directory and it won't work! The usb drive is not recognized. I know for sure one of the drives worked well in my Tron LE. Does anyone have advice??
#971 2 years ago
Quoted from Oneangrymo:
did you move dip switch #8 to on?
#972 2 years ago
Yes for sure.
#973 2 years ago
which of the modded codes are you trying to load up?
#975 2 years ago
Check the seating of the ROM chip. They can be bad and it might have to be replaced.
https://pinside.com/pinball/forum/topic/tech-stern-sam-bootrom-twdle-will-not-update
#976 2 years ago
Quoted from ezeltmann:
I dont think its the rom chip. I think its the way the usb drive is formated.. it doesn't even recognize it. I just do fat 32, but is there some sort of other parameter I am not doing right?
#977 2 years ago
Give this a try quick. Download the newest code off Sterns site and try to load that on your machine. If it works then you will know its not the flash drive or rom chip.
#978 2 years ago
Ok i will try that when I get home, thanks for advice. I went through a similar issue with my Tron LE. Turned out to the the USB drive. But the one that worked on my Tron, I formatted it to use on TWD, but it doesn't work! Crazy stuff
Mo!
#979 2 years ago
I just picked up my TWD Pro yesterday and this morning I installed the regular version of Cleland's 1.56 rom. I love the sounds but am getting a little flak from my wife over some of the callouts with my 9 and 10 year old kids playing it. We have a lot of the kids friends over to play in the arcade. Was there ever a true PG version of Cleland's released before I go learn how to use Pinball Browser or tell the wife to stuff it?
#980 2 years ago
Hello,
I'am a new french TWD LE pinball owner.
I'm looking for a download link for Ed Zeltmann custom code.
Could you help me please?
#981 2 years ago
Quoted from Psykopat:
Hello,
TOOL Music replacement - show voices
https://www.dropbox.com/s/ram2ytit1j0youe/TWD156TL.bin?dl=0
EVIL DEAD 2 Sound replacement
https://www.dropbox.com/s/je07knkx7hnbzhf/ED156LE.bin?dl=0
Walking Dead Show Voices / custom voice music mixes / We are the walking Dead, thunder match sequence
https://www.dropbox.com/s/fak3n9y8y262cnb/TWD156ez.bin?dl=0
None are family friendly.
#982 2 years ago
Thanks for your answer Ed!
I tried your custom rom but unfortunatly, this is not the one i'm looking for.
I'm still looking for kpg's rom with the whistle of the saviors in outlane.
I sent him a message but he was not connected since the 15 september.
If someone have this file to share with me it will be great.
Thanks in advance and have a nice day.
#983 2 years ago
Go to the top of this page to the "key posts" index. It shows KPG's version as post 714. Just click on that link and it will take you to the post.
#984 2 years ago
Thanks,
I have no problem to found the post.
But Download link are down on post 714 and 757...
#985 2 years ago
Finally got it to work! Was the USB drive all along. had to get a PNY 16gb then everything worked great.
Awesome update, I like it much better then the other voice call outs.
1 month later
#986 1 year ago
Does anyone have a link to the most recent KPG version for the TWDLE?
All previous links I found are dead.
11
#987 1 year ago
Cleland - will you be making an update to go with Stern's new update ? Please please please ?
#988 1 year ago
I’ll be making my NIN/RH mix on top of Cleland callouts if/when he gets around to it, he is a busy guy.
#989 1 year ago
My walking dead le came with custom sound..is there anyway to tell which/whose sound file is in my game?
#990 1 year ago
Quoted from ATLpb:
I won't be upgrading until you are ready. I really like your mix.
I guess we will need a new ROM file for colourDMD as well.
#991 1 year ago
Quoted from ATLpb:
Thanks RandomKG, can't believe the timing of this. I'm working on GOTG, the home-brew Last Starfighter, and now this! Hopefully, I can just run my macro and not much has changed. I have not downloaded yet, but will later this evening.
#992 1 year ago
Quoted from cleland:
Thank you!!!!
#993 1 year ago
Hearing that you are working on GotG just increased the probability of me buying one by several factors. I can't believe they didn't get authentic callouts from the films as the scripts of those movies are just so tight. Can't wait to hear your version!!
#994 1 year ago
Negan whistle for outlane drain? Can’t remember if that was your code.
#995 1 year ago
Quoted from Lermods:
I have the Negan whistle mixed in with my dubstep shooter lane groove.
#996 1 year ago
Thanks so much Cleland- we patiently await...you rock! Really hope the Macros have not changed much so it is not too difficult for you.
#997 1 year ago
Quoted from Radagast:
I agree. Your stuff is awesome Cleland. Your work on TWD is spectacular. Super excite to see what you do on GOTG. Put me down for a donation when you finish.
#998 1 year ago
Wait ... to have a pro ... this is clelands I have isn’t it?
#999 1 year ago
cleland if you can add a sound sample when you are awarded an EXTRA BALL for scoring (I have extra ball instead of replay set for award), that would be great. Its missing in your current wonderful creation.
#1000 1 year ago
Quoted from Malibu-SS:
Should be Cleland in there.
5,800
Pittsburgh, PA
$ 445.00
MI Pinball Refinery
€ 22.00
YOYOKOPTER MODS
