(Topic ID: 236035)
Walking Dead does not register ball drain sometimes.
By action76
2 years ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by mannymasy
#1 2 years ago
I have had this issue since I got the game NIB. I talked with Stern about it at first and they said to adjust the switches in the trough. I have adjusted the switches until I am blue in the face. I could get it better but it would never go away. I decided to just live with it at the time but now we are having tournaments and this is unacceptable for that reason. This last time I did it and I thought I had done it because it played 3 games without issue but after that it seemed worse than ever. I know of another person who had this problem and said they had a tech that came out and still couldn't figured it out. Has anyone else had this issue and if so what, if anything did you do to fix it? All new trough switches? Some other adjustment I don't know about? Any help would be much appreciated.
#2 2 years ago
When my met pro pf was replaced my new pf did this.
Check this out next time. When my ball would drain, open the coin door and look to see if the ball through switch(es) were not clicked down all the way. Probably the case. Just tweak the switch arm with a switch adjustment tool until it is a little softer and easier to be clicked down
#3 2 years ago
Remove balls and put game in switch test mode. Roll a ball into the drain and see if they all register. If they do, then test the opto boards in the trough. It’s either a flaky switch or a bad receiver/transmitter on one of the two opto boards.
#4 2 years ago
I would follow the wires and any IDC connectors you run into, be sure the wires are pushed in tight, making good contact, and not cut in half in the connector.
1 month later
#5 2 years ago
good evening, does anyone know what reference has the screw and the piece of grip of the board that holds the mechanism of the zombie head in this area? Thank you!!!
