(Topic ID: 138392)
VUK Opto Emitter looks on but doesn't register
By n1teowl
  • 12 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by LTG
#1 4 years ago
I have a VUK opto that isn't working right. It always shows the beam as being blocked, even when it isn't. I tested the receiver opto with a flashlight and it seems to be working fine. I would assume that this means the emitter is bad, but I can see that it's on when I look at it. Two questions:
1) Does it matter if you can see a bright red light coming out of the emitter LED? Should it be only visible with a digital camera?
2) If you can see a bright red light, does that mean that the reciever should be picking up the signal?
#2 4 years ago
What game please ?
Stern and Williams are different.
LTG : )™
#3 4 years ago
It's a Sega Batman Forever.
#4 4 years ago
Should be glowing red both sides. Same part used both sides.
LTG : )™
#5 4 years ago
Do you have an idea what I should try next? The "dark" receiver seems to work fine when I shine a light on it, but nada when the red LED from the emitter board shines on it. Seems like it should work...
#6 4 years ago
Quoted from n1teowl:
I'd replace it.
LTG : )™
#7 4 years ago
I'll give it a try. On a side note, what exactly does the VUK opto do, look for jams? It saw that it was unplugged today and it must have been that way since I got the machine. It seems to be functioning okay without it.
#8 4 years ago
A ball goes into the VUK. The pinball machine goes "oh look, a ball went into the VUK". Then the machine being wiser now kicks the ball out of the VUK.
LTG : )™
#9 4 years ago
Yes, I get that. What I don't understand is why it kicks balls out despite the opto receiver being unplugged.
#10 4 years ago
It thinks a ball is there and kicks.
No ball the opto switch is closed. Ball there blocking the opto the opto switch opens. No power - game thinks the switch is open.
LTG : )™
#11 4 years ago
When it's unplugged it doesn't kick until there is a ball in there. I assume it's because it knows it just released a ball into the VUK, not because the opto is telling it there is a ball in there. When I plug it in, I guess it starts receiving a signal and thinks the switch is open and starts kicking.
#12 4 years ago
What does it do in test ?
If the opto isn't working, the game doesn't know a ball is in there. After a bit it may go into ball search and kick that and other things.
LTG : )™
Gweem's Mods
$ 279.95
Pin Stadium Pinball LEDs
3,000
Nashville, TENNESSEE
Professor Pinball
PinSound
