(Topic ID: 239847)
Volume Pot compatability
By Calipindave
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Calipindave
#1 1 year ago
Hi guys.
The volume pot on my EBD is flaky.
The usual sources seem to be out of the one needed for this game.
I believe it is a 100 ohm 5 watt? Is this correct.
Is this a proper substitute? It looks identical to the one on Marco's page and the specs are the same,
amazon.com link »
Dave
#2 1 year ago
If the specs are the same then it can be installed.
Mounting is always and issue. Is the way this one mounts the same? Do you have enough wire to put this one in?
I usually check GPE, Allied and Mouser.
As long as the OHM range, watts and linear or audio all match it is a go.
#3 1 year ago
Quoted from PinballAir:
It looks like it mounts the same, even including the same tab.
Does anyone know if these specs are correct for the early Bally SS games?
Dave
#4 1 year ago
yes. it will work fine.
#5 1 year ago
Quoted from jj44114:
Thank you
Dave
#6 1 year ago
PBR has them:
POT,2W 10% 100 OHM-WITH HDWR
GTB-XO199 $4.00ea
#8 1 year ago
Excellent. Thanks guys.
Dave
$ 50.00
$ 8.00
Third Coast Pinball
$ 9.00
$ 49.99
PinballElectronics.com
Third Coast Pinball
