New! Dark mode!
(Topic ID: 276750)
Voltage for Williams SA-3-23 Coil
By scampa123
45 days ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 45 days ago by slochar
    #1 45 days ago
    I’m planning to test a coil outside of my machine for a drop target.
    I want to use my bench power supply.
    Could someone tell me what voltage I should use for the SA-3-23 coil? I cannot find what it is rated. 12v? 24v?
    Thank you,
    #2 45 days ago
    A coil is just a spool of wire of a certain gauge for a # of turns.... for instance, what's the difference between a 23-800 (800 turns of 23 ga. wire), and 23-800 50v? (800 turns of 23 ga. wire)..... nothing.
    You're burn it out quicker at higher voltages for sure if you put full on for long pulses.
    The games it would have come out of would have been 24v (ac), 50v DC, 28vdc, or 50vdc.
    The usual way to test a coil is to take a resistance measurement of it and compare to pinball medic's chart (also at flippers.com IIRC) - not hook it up to power. Resistance of coils is usually relatively low and is seen almost as a dead short (<20 ohms)
    #3 45 days ago
    There should be more to the part number than that. Can't tell how strong the coil is without it.
    #4 45 days ago
    Sorry the part is SA-3-23-850-DC
    I know I can test resistance but I am trying to work on my drop targets and would like to power the reset outside of the table. I didn’t think it would be a big deal to power it via my adjustable power supply.
    Thanks again
    #5 45 days ago
    Quoted from scampa123:
    Thanks again
    25-30VDC should work fine for that coil. Williams games use similar for their 3 banks and run at 28VDC
    #6 45 days ago
    Thanks again
    The answer would be that you set your supply to the same voltage as your machines supplies then to get the correct test result.
    $ 16.00
    Tools
    PinballSolutions.eu
    $ 60.00
    RobTune
    $ 5,899.00
    Gulf Coast Pinball, LLC
    $ 44.95
    PinBoss Mods
    $ 18.95
    $ 5,999.00
    Classic Game Rooms
    $ 34.00
    The MOD Couple
    Cabinet Parts
    Ramp-O-Matic
    $ 45.00
    $ 27.95
    G-Money Mods
    $ 6,199.99
    Apparel - Unisex
    Pinball Wheezer
    $ 19.99
    $ 50.00
    Apron Envy
    $ 9.99
    $ 12.95
    COINTAKER.COM
    $ 9.95
    $ 48.00
    £ 32.00
