(Topic ID: 217313)
Volley start up issue
By presqueisle
2 years ago
  • 28 posts
  • 10 Pinsiders participating
  • Latest reply 2 years ago by presqueisle
#1 2 years ago
Volley was 100% until is wasn’t. Went to start a new game and the 10,000 score reel did not reset, and the score motor ran non stop.
Been cleaning and checking switches but am missing something obvious I think.
#2 2 years ago
If you set the 10K reel to 0 manually does that stop the motor? Likely your 0 pos. sw. needs a tweak. Look here for more info: http://www.pinrepair.com/em/index2.htm#reels
#3 2 years ago
Quoted from presqueisle:
Agree with currieddog
It sounds as if your zero position switch may look like it's closing but you need to put more pressure on it via adjusting. Then, your score motor should stop. This problem usually happens when you 1st shop a game and the problem appears or you haven't played the game in awhile - pretty common.
#4 2 years ago
Very sorry I deserted this. I had a family situation pull me away, and I don’t keep this game at home. Thanks for the help so far, I really appreciate it.
The zero position sw looks good and has been cleaned.
The motor does stop when 10k reel is reset to zero.
Game actually played once! But when I went to start another game the 10k reel wouldn’t reset again.
Reset to zero again.
Tried to start another game and it won’t play now and ball won’t eject to shooter lane.
10k reel is snappy and all looks good. Manually going through the 1k reel activates the 10k.
The reset bank will activate only when game was turned off, then on again (but 10k reel won’t reset nor will ball kick out).
If a new game is started without having first turned game off/on...Reset bank will not trip.
#5 2 years ago
Sometimes a switch can look closed & even reset score reel to zero but insufficient contact to properly complete reset sequence hence score motor continues to run. To test this suggest you jumper the 10k zero position switch. If reset occurs & score motor stops that is your problem-reclean & reset switch contacts.
#6 2 years ago
The score motor does not continue to run now, so I’m on to getting the 10k reel to reset. I don’t have a jumper here.
#7 2 years ago
Very easy to make with wire and two small alligator clips.
#8 2 years ago
I have everything working now, but the 10k reel reset issue. Game plays perfect otherwise.
So I’m ahead of where I started.
All relays and switches have been gone over. All operate well but I’m at a loss to what I’m missing. I’m more of a visual tech and that fixes 95% for me. But this one is beating me up (sore back
I have the schematic here but those get tricky for me on certain issues. I’m not sure if I’m following it.
#9 2 years ago
The score reel reset circuit works off a single wire daisy chained from probably the 10s reel switch stack ending at the 10k reel switch stack. Check the 1k switch stack for the burned off wire connection.
#10 2 years ago
Those Decagon reels can be tetchy. A visual doesn't ensure that things are correct. Take a look at the link I posted above.
#11 2 years ago
Quoted from pinballdaveh:
Thanks, I’ve been thru them but I’ll have to check again.
Quoted from currieddog:
I’ll go thru everything again. I appreciate the help.
I was wondering if a switch on the score motor would cause this.
Again, everything plays now, just the 10k reel is not resetting.
I’ve been thru the score motor pretty well but wonder if I may have missed something there.
I’m close! I’ll get back to it this afternoon/eve.
Driving me a little batty.
#12 2 years ago
Check the AX relay switch with BL+RED wire.
#13 2 years ago
Get me a high quality scan of the schematic from e.g. Staples ($2) or Kinkos ($6), and PM me some contact information and I'll talk to you on the phone.
#14 2 years ago
Quoted from woz:
Check the AX relay switch with OR+RED wire.
The AX is good I think. Fingers crossed.
I believe I found my issue, alhough I haven’t fixed the problem yet. It has to be in the score reels.
When re-examining the 10k reel it looked good. Then I compared the switch action to a reel that was resetting properly...and I noticed they were off. After going back and forth I was getting different reels to not reset, make the score motor run etc. Everything but getting the 10k to reset, haha. I think i have the sequences off. It’s tricky. My eyes were strained so I’ll have to start again in a couple hours.
Quoted from HowardR:
Much appreciated.
I feel the reel switches are my issue now. I need to sort it out with fresh eyes. There are two forward strokes but certain switches open and some stay closed... That’s my issue I’m pretty sure. I think I also went through and misaligned some when I thought I was aligning. Hate when that happens New problems pop up!
Thanks for the offer and I’ll let you know.
#15 2 years ago
I had the wrong AX switch identified in my previous post and have edited it.
#16 2 years ago
I've had that issue, many times now.... LOL.
#17 2 years ago
I had to comment, Volley is the first game my Dad brought home in 1979
And still have it today, 500 + pinballs later.She is so cherry its crazy
She's priceless
#18 2 years ago
Sheesh I must be dumb and/or blind.
Vote now!
So after verifying the correct score reel positions for the zero, one and nine switches, I initially thought I had fixed the 10k reel issue. It reset! But then I noticed the 100s didn’t reset. Motor spins etc. I went out and bought a bright work light (I’m not at home where my tools were left, bought a magnifying glass, cleaned and sanded everything etc.
I’ve looked at it up and down. The switches have to be good.
Since my score reel issues are migrating I’m left to believe the problem lies elsewhere.
*While trying to fine tune all the reels I did keep going back and forth between them because different ones at times wouldn’t reset. I thought I was going crazy. Maybe I am.
Would my AX relay cause this? (Meaning: random reels not resetting). It’s been checked over multiple times ...but I sure am missing something.
#19 2 years ago
Check the solder tabs and connections. I had to reflow the match unit pcb before it would work on mine. Since messing with the score reels has changed things, I believe that is where your problem is.
#20 2 years ago
Quoted from D-Gottlieb:
Thanks for the help.
On the reels?
The only reason I was hesitant to go there is that now they have all taken turns not resetting. I’m not sure if my tweaking of those switches has done anything either since I didn’t find noticeable issues.
#21 2 years ago
On the reels. There are a couple with redundant contacts. This is in case one gets dirty. Make sure they all work as they should and are clean. Solder tabs need to be straight and away from adjacent tabs.
#22 2 years ago
Fixed!
Thanks for everyone’s help.
It was in the AX relay. A tough to see switch had me fooled, which isn’t hard I guess
#23 2 years ago
Often, the resolution of a problem can be as good as playing a hi-score game.
Congrats...........
#24 2 years ago
Way to hang in there and get it fixed Dave
#25 2 years ago
Interesting behavior from an AX unit. Good job.
#26 2 years ago
Why's that interesting behavior?
#27 2 years ago
Actually, I stand corrected. Each reel does go through the AX. I had to look at the schematic again.
#28 2 years ago
It was a back switch that actually moved slightly, harder to see and it was making it look like contact was being made. But it was from the pressure of the adjoining switch that was making the illusion. It was one of those y, or tuning fork looking, type double switch blades. Pressure on one moved the other. Drove me bonkers.
$ 4.49
$ 6.50
$ 139.00
PinWoofer
$ 19.95
$ 334.95
$ 1,000.00
Playfields
Pinball Playfields
$ 74.00
Id Rather Play Pinball
$ 299.99
$ 239.00
Tilttopper
$ 89.99
$ 109.99
$ 114.00
Lighting - Backbox
The MOD Couple
$ 55.00
Pinball Photos
Pinball Pimp
$ 229.99
$ 120.00
G-Money Mods
$ 149.00
Sparky Pinball
$ 35.99
Lee's Parts
