Gottlieb Volcano system 80, model 667
I've been having two issues with the subway kicker:
• Sometimes, but rarely, it takes several attempts for the kicker to get the ball back onto the play-field
• The ball almost always goes down the drain or very close to going down the drain when it shoots back onto the play-field
When I examined it, I discovered somebody installed an A-19300 coil (7.8 ohms) on the subway kicker and the fire-pit. The schematic shows that these coils should be A-4893 (2.1 ohms). So I replaced them both with the correct coils and sleeves from PBR. (The fire-pit was also ejecting balls down the drain, but the correct solenoid coil fixed this and it's consistently knocking the ball into the pop bumper instead of the drain.)
Now the ball is shooting out of the subway harder and mostly going towards the right flipper as it should. However, during play, I got a multi-ball and 1-2-3... all three balls shot straight down the drain.
It also seems like this solenoid is not always firing as hard as it should. The other issue where sometimes it's not able to kick the ball all the way out is still happening occasionally. The ball rolls back down and when this happens, it takes a couple more attempts before it's ejected.
Took the metal cover off and can see what's happening. When the ball stays in the groove between the two rails, it shoots out where it should. When the problem happens, the ball leaves the groove of the track and exits the play-field opening from on top of the left side track rail, which leads it straight down the drain.
There does not seem to be any adjustments in any of the mechanisms here, short of bending metal or drilling new holes. I am just not understanding what's causing this problem. It looks like the hammer might be extending too far and hitting the ball off to the side instead of keeping it centered. However, this too has no adjustments. The solenoid plunger stop is about 5/16" long, but I don't know what it's supposed to be.
I still have absolutely no idea why sometimes it shoots out like a bullet, and other times it takes two or three attempts to eject one ball. And no clue if it's coming out of the track groove because it's being hit too far, too hard, or too soft.
What I've done:
• Cleaned and waxed the metal tracks, guides, etc.
• Buffed, cleaned, and waxed the hammer head that hits the ball
• Slightly bent the metal side walls to help guide the ball up the center and stay in the groove. (I left a little clearance because I did not want the ball getting pinched.) EDIT: I only did this on the upper end near to where the ball exits.
It's still not working consistently.
The video and photo shows the ball coming out of the groove and onto the left rail while being ejected.
Any tips, hints, clues appreciated.
Thank you!
EDIT: Read this entire thread to the end since there are a few red herrings in between as my idea of the theory-of-operation evolves.
