Circling back to this stumper from my Gottlieb Volcano.
Subway kicker when fires, blows the driver mosfet & it’s respective fuse (F15)
Replaced diode & coil.
Checked red-brown-brown. (Driver to coil wire)
Until the bottom of the playfield.
If I unhook the coil from the MPU. Then trigger it. Fuse and mosfet are fine.
Last thing I did before this issue popped up was repin the MPU to Driver.
Checked it against my Black Hole harness & I didn’t mix up any wires. Only added extra ground & voltage wire as recommended.
Running a NiWumpf Driver & MPU
But I have an original MPU and they neither one fix this issue.
I should note that both drop target banks are on the same ground line & both of those work fine.
Any thoughts?
